it'll be nice to see someone do the "OEM+" thing properly.
Finally found my IS.
I had the suspension installed. Im using Eibach springs and the front seems to be higher than I expected. Should i cut a coil or replacing the spring pads would help? Thinking of another inch drop at least. Would that be half or 1 coil?Last edited by atan88; 01-27-2010, 12:47 AM.Comment
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
Yup it was the right rear and I had both sides replaced. Its all nice and quiet now. Next is I need to buy a stock AFM. Mine seems to be out of tune.
Give the springs a few days to settle. If they are still to high for you then try removing all the spring pads first before resorting to cutting a coil. My 1st 318is that got totalled had a reverse rake and my 2nd one is sitting abit high and also has a reverse rake. Im going to remove my spring pads and I also ordered a set of 15mm drop hats to try and cure this problem. If worse comes to worse ill cut a coil with ya! LoL
RIPComment
When you get teh Sideskirts installed, tell me what you payed to get them installed. I got some skirts, and want to have them professionally done.[/url]
Team USA Wrestling 67KG
Team USA Wrestling Strength And Conditioning CoachComment
you ever get the sideskirts installed?
how much it cost ya?[/url]
