New Mods
  • Hawk
    • 549
    New Mods
    Havent posted on here for awhile. Got a magnaflow exaust with high flow 1psi cat and 2.5 in pipe. Two JL W3v2 12's with an alpine 301 amp. And Euro ellips.
    Summer '85 E24 635csi Winter '88 E30 325iX, I lose 25% of my hp before I even turn the key.
  • BMW BMXER
    • 2325
    How much power is that amp pushing?
    Any direct rear shots of the exhaust?
    Sold it.
    • Hawk
      • 549
      The amp is 400 at 2 ohm stable the Jl's are 6 ohm. Ill get some rear shots tomorrow of the exaust.
      • Jordan
        • 12913
        The MRD-301 runs 350 Watts x 1 RMS at 2 Ohm. Not enough to power 2 12W3v2's.
        Is that box made out of 3/8in plywood? That is the worst box EVER. You never ever ever EVER make a box out of plywood, let alone that thin.
        https://mtechniqueabs.com/
        • Hawk
          • 549
          The factory tests each amp and give rms on a sheet that is included with the amp. Even if it was only 350 the subs are 6 ohm. Not 2 or 4. And it is made out of 3/4in ply. Mabey you would like me to take a picture of the spec sheet on them. Im am just under optimum for them. The alpine is soon to be replaced by a jl 500/1 slash series amp. The alpine was used to power my Image dynamics 10 in. Im interested to know why you wouldnt build a box out of plywood if you would care to enlighten me on the subject. The box is totaly sealed and does not rattle or buzz.
          • Jordan
            • 12913
            Plywood is a very shitty box material. End of story Plywood is on average 1/2 as dense as the same thickness MDF. Plywood is also filled with imperfections and the laminations can vibrate loose.
            You understand that at 6OHMS your amp is making alot less then 350watts right?
            • BMW BMXER
              • 2325
              Plywood flex's and shit, if you are using wood use mdf. Some other people have used oak and pine and shit but thats weird show stuff.
              400 watts for 2 w12v2's is underpowered. I use a 600 watt amp for one.
              How does the magnaflow sound.
              Sold it.
              • kencopperwheat
                King of Kegstands
                • 14396
                Plywood flexes too much and will resonante when it vibrates. For 2 12"s, you're going to want to use 1/2" MDF.
                Originally posted by Gruelius
                • DSchultz325e
                  • Aug 2004
                  • 1158
                  Meh I'd use 3/4" MDF.
                  I retired my E30 for now...
                  E46 323i
                  David Schultz
                  • Jordan
                    • 12913
                    My box is 3/4in MDF.
                    • DSchultz325e
                      • Aug 2004
                      • 1158
                      So were both of my sub boxes :x Stupid thieves. You're definitely gonna want to reconstruct it. Get some wood screws, wood glue, silicone sealant, and some polyester fiberfill (pillow stuffing).
                      A sheet of 3/4" MDF is sold at Home Depot for about 20-25 bucks a pop. You shouldn't have to spend over 40 dollars to construct a good box. Carpeting it will bring it to around 50. Follow all the specs outlined by JL, and USE the materials they recommend. Don't skimp out on stuff like this, it will end up falling apart or just degrade the sound quality. The box is essential to the woofer's operation.
                      E46 323i
                      David Schultz
                      • Axxe
                        • Aug 2004
                        • 3355
                        Dude, I have that amp driving one 4 ohm sub and it feels a little underpowered. One 2 ohm sub is all it's designed to run.
                        Keep it slideways!!
                        • Digitalwave
                          is a poseur
                          • 6293
                          Bling bling.
                          RISING EDGE
                          • kansas-ix
                            • Jan 2004
                            • 1600
                            like the euro ellips. now just tuck or plastic for the bumpers,lookin good.
                            E30 325ix 62k
                            • Mystikal
                              Wheel Fitment Expert
                              • 9602
                              You know what guys, I'm thinking the subs are dual 6 ohm (the W3V2's are D2 D4 or D6), and he's running the amp at 1.5 ohms. :shock: :shock: :shock:
