The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Eric
    • 5142
    #391
    Originally posted by Dj Buttchug
    im on 970cc right now. I could. Hell i should. Will see.
    :up:
    • Dj Buttchug
      • Jun 2010
      • 7649
      #392
      went for a drive tonight. Its so nice to be able to enter a corner just under boost, kick the clutch, and have enough power to hold a slide.
      money well spent
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • TheTacoMan
        • Nov 2011
        • 2308
        #393
        Wait until you hit your goal. 300whp is pretty sweet.
        I might have missed it but how much boost are you running ?
        • Dj Buttchug
          • Jun 2010
          • 7649
          #394
          16psi right now. It feels amazing.
          Ig:ryno_pzk
          • TheTacoMan
            • Nov 2011
            • 2308
            #395
            What are you intake temps at? Im surprised the m42 throttle body is a restriction at 16psi.
            • Dj Buttchug
              • Jun 2010
              • 7649
              #396
              it depends, Im usually in the 90s. If I drive when its cooler the air temp is better.
              Its only up high that I cant get more air in. Anything sub 5500 revs and its all good. the design is that double plate style. It sucks real bad
              Ig:ryno_pzk
              • TheTacoMan
                • Nov 2011
                • 2308
                #397
                Damn, well meth is an option to help you get over the 300 hump. My intake was a bit more than yours though so the gains might not be the same.
                • Dj Buttchug
                  • Jun 2010
                  • 7649
                  #398
                  you reno boys and your meth. You guys really are nuts. I need to get on your level.
                  I also need a bigger intercooler
                  Ig:ryno_pzk
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    #399
                    I have the smallest intercooler among everyone, I think its some thing like 5Hx26LX2.5W. Meth helps alot in that aspect.
                    I know Id be running e85 if they had it here in Reno. I know when I was at 250ish whp I had some traction issues with an automatic.
                    I still have yet to setup my intercooler sprayers too, I need to get to that.
                    • Dj Buttchug
                      • Jun 2010
                      • 7649
                      #400
                      same here. I have my setup made but not installed.
                      Will see how it goes after that. Im about 40 hp short of my goal right now. I think I can get there on 91 pump with a better intake and tb.
                      Ig:ryno_pzk
                      • ethirty24
                        • Sep 2013
                        • 16
                        #401
                        looks sick! must feeel amazing to have that power!
                        • DesertBMW
                          • Aug 2011
                          • 1029
                          #402
                          What brand and part number are these wheels? Are they 15"? Where did you buy them?
                          • Dj Buttchug
                            • Jun 2010
                            • 7649
                            #403
                            son of a BITCH
                            I just fried 2 out of 4 of my coil drivers.
                            F*CK you Megasquirt
                            Ig:ryno_pzk
                            • Schnitzer318is
                              • Jan 2008
                              • 2057
                              #404
                              Weak. How did that happen?
                              And how long did it take you to figure out it was the drivers? ;)
                              I wish I could shove 16psi into my m42 but the little turbo I'm running bails out around 12psi. Even then it falls on its face (the turbo) above 5500rpms.
                              "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                              91 318is Turbo Sold
                              87 325 Daily driver Sold
                              06 4.8is X5
                              06 Mtec X3
                              05 4.4i X5 Sold
                              92 325ic Sold & Re-purchased
                              90 325i Sold
                              97 328is Sold
                              01 323ci Sold
                              92 325i Sold
                              83 528e Totaled
                              98 328i Sold
                              93 325i Sold
                              • Dj Buttchug
                                • Jun 2010
                                • 7649
                                #405
                                bout 2 seconds. It stinks up the whole inside of the car when they smoke off.
                                Im dealing with a cold start issue and I cant get a decent start up with out extensive cranking. hot starts are almost perfect but cold ones sucks. If I crank to long it overloads my coil drivers and they fry. I ordered the updated ones that have a failsafe so this wont happen anymore.
                                Ive been driving around in economy mode at 8 psi. haha. All this work and im not even using all my boost.
                                wtf was i thinking.
                                Ig:ryno_pzk
