The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • NKRoberts
    • 909
    Looks good.
    Vinyl Lettering
    • shiftbmw
      • Oct 2005
      • 2012
      I'm loving the wheel color man.
      "The best argument against democracy is a five-minute conversation with the average voter." - Winston Churchill
      • Stevo-iX
        • Jul 2010
        • 231
        looks very good, that stance is perfect imo. pink makes it even better
        and hot damn your exhaust is low.
        • fiftytakedowns
          • 2460
          any oil cooler?
          [/url]
          Team USA Wrestling 67KG
          • Dj Buttchug
            • Jun 2010
            • 7639
            thanks for the props guys. No oil cooler yet. I may install one if I start having temp issues.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • e30m3s54turbo
              • Jun 2010
              • 3223
              Nice work.
              • Mike The Bavarian
                • 488
                not gonna lie, this car is fucking awesome! turbo m42<3
                • MrSlacker
                  • 2494
                  Turbo M42 makes me wet every time I see them... one day I'll pull the trigger on one
                  My Seller/Buyer Feedback
                  Performance Aftermarket Parts & Accessories
                    • 34839
                    I would move your o2 sensor downstream a bit, at least if you want it to last very long.
                    you'll also probably want a lot more rubber if you want to actually put some power down. :p
                    • noE30
                      • Jun 2008
                      • 2260
                      Love it! Got any videos
                      Flickr
                      @michael.colby on Instagram
                      "All he needed was a wheel in his hand and four on the road"
                      • erik325i
                        • Jan 2005
                        • 3567
                        Car looks nice. That exhaust clearance looks scary though.
                        Originally posted by Dj Buttchug
                        I dont know what happened. my upper and lower pan gaskets failed. as well as my rear timing case gasket. I was more pissed than I was anything. Maybe it was assembly error on my part. the world may never kno. I now can remove my engine in less than an hour thanks for VR gaskets
                        I don't like VR gaskets either. I especially won't use their m50 oilpan gasket as the bolt holes don't line up correctly.
                        Erik
                        • Danny
                          • 14216
                          I agree with both of these statements.
                          My turbo M42 was a handful even with real sticky 215s. I'd move your o2 sensor back closer to the stock location. Its way too far upstream as is.
                          Also, paint your intercooler and piping black, it'll save you a lot of hassle with the po-po.
                          Also, what are you doing for tuning? Don't waste your time with a blow through AFM, just spend the money on MegSquirt or some other stand alone and save time and headaches.
                          • Dj Buttchug
                            • Jun 2010
                            • 7639
                            maybe this is why I am getting an o2 sensor code. It is only temporary until tuesday when i can weld in my new bungs down lower.
                            Im pretty much shafted for tires then...anything bigger than a 205 and I rub. will see what happens when i get five luggers attached. may have to change a few things up in this area
                            Ig:ryno_pzk
                            • Danny
                              • 14216
                              Also, put an air filter on before you bend your compressor fins.
                              • ethrtyiS
                                • 8147
                                that thing is very clean. i want me a tarbo so bad.
                                '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
                                my feedback thread
