Bay Area E30S52: No More Slush Box + More Horsepower
  • b15azn
    • Dec 2009
    • 88
    #91
    ahhaha first time see that license thing on an E30. Awesome!!!
    • Simon S
      • Oct 2004
      • 3758
      #92
      Most excellent.
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • bernzpeed
        • 3917
        #93
        My name is Bong, Jane Bong....lol.
        89 E30 S52
        Transaction Feedback.
        • mcr_driver
          • 4491
          #94
          win...simply much win...how much was that project?
          • bernzpeed
            • 3917
            #95
            extra set available.... pm me.
            89 E30 S52
            • !AjHoWzA!
              • Jan 2010
              • 1140
              #96
              Looks great bro! Love the color white on E30's
              '91 318is
              • bernzpeed
                • 3917
                #97
                thanks!
                89 E30 S52
                • dmoney(AB)
                  • 1372
                  #98
                  damn, if only I could do that for the rear :p
                  mtech1/2jzgte/r154/275tire
                  function>form
                  • bernzpeed
                    • 3917
                    #99
                    you can... hinge in the bottom. actuator on top to tip it over and motor that winds up to pull it back.
                    89 E30 S52
                    • bernzpeed
                      • 3917
                      #100
                      IS Side Skirt Installation
                      Parts you need:
                      51 71 1 947 059 Cover left (fender)
                      51 71 1 947 060 Cover right
                      51 71 1 947 063 Cover left (body)
                      51 71 1 947 064 Cover right
                      51 71 1 933 719 Clamping bolt
                      NOTE: You have to remove the bolt at the bottom of the fender and replace it with a similar but longer screw bolt instead of using this.
                      Trust me it will work better.
                      51 71 1 927 439 Plug (You need 2)
                      51 71 1 938 940 Clamping (You need 10)
                      51 71 1 932 996 Grommets (you need 12)
                      51 11 1 942 789 Rivet (you need 4)
                      51 71 1 959 929 Clamps (You need 12)
                      My car before install
                      Brand spanking new
                      Figuring out where to fit all clips
                      Test fitting the whole thing.
                      NOTE: Make sure you the both pieces TOGETHER.
                      Otherwise, you will get this gap
                      Marking the tip of the clips so it transfers to the body.
                      Drilled out a hole with a 3/8 step drill
                      Inserted the grommet
                      Tap tap tap
                      Tadah!
                      Installed the bottom clips
                      Lined up right
                      Making a hole for the rivet
                      Lined up perfectly the second time around
                      My riveter is too small for the BMW rivet
                      Temporary fix
                      89 E30 S52
                      • bernzpeed
                        • 3917
                        #101
                        Also this was laying around for the past 2 years so I figured I would put it to good use.
                        My trunk is fully lit. Yeay!
                        89 E30 S52
                        • bernzpeed
                          • 3917
                          #102
                          Also tried this one since the wheel was off
                          89 E30 S52
                          • freeride53
                            • 11972
                            #103
                            So much progress lately!
                            1983 Peugeot 505 STI
                            1992 Volvo 240 Wagon
                            • bernzpeed
                              • 3917
                              #104
                              Finally had some energy to do the projects. Still procrastinating on the dash swap.
                              89 E30 S52
                              • Tismael711
                                • 791
                                #105
                                Worthwhile thread. You do good work.
