ahhaha first time see that license thing on an E30. Awesome!!!
Bay Area E30S52: No More Slush Box + More Horsepower
My name is Bong, Jane Bong....lol.Last edited by bernzpeed; 08-07-2011, 11:20 AM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Transaction Feedback.
extra set available.... pm me.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
thanks!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
you can... hinge in the bottom. actuator on top to tip it over and motor that winds up to pull it back.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
IS Side Skirt Installation
Parts you need:
51 71 1 947 059 Cover left (fender)
51 71 1 947 060 Cover right
51 71 1 947 063 Cover left (body)
51 71 1 947 064 Cover right
51 71 1 933 719 Clamping bolt
NOTE: You have to remove the bolt at the bottom of the fender and replace it with a similar but longer screw bolt instead of using this.
Trust me it will work better.
51 71 1 927 439 Plug (You need 2)
51 71 1 938 940 Clamping (You need 10)
51 71 1 932 996 Grommets (you need 12)
51 11 1 942 789 Rivet (you need 4)
51 71 1 959 929 Clamps (You need 12)
My car before install
Brand spanking new
Figuring out where to fit all clips
Test fitting the whole thing.
NOTE: Make sure you the both pieces TOGETHER.
Otherwise, you will get this gap
Marking the tip of the clips so it transfers to the body.
Drilled out a hole with a 3/8 step drill
Inserted the grommet
Tap tap tap
Tadah!
Installed the bottom clips
Lined up right
Making a hole for the rivet
Lined up perfectly the second time around
My riveter is too small for the BMW rivet
Temporary fix
Last edited by bernzpeed; 10-05-2011, 10:05 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Also this was laying around for the past 2 years so I figured I would put it to good use.
My trunk is fully lit. Yeay!Last edited by bernzpeed; 10-05-2011, 10:12 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Also tried this one since the wheel was off
89 E30 S52
So much progress lately!
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
Finally had some energy to do the projects. Still procrastinating on the dash swap.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
