Hartge/Dbilas M20 NA Muscle - ITB Content - *WITH VIDEO*
  • gforce323i
    • May 2004
    • 81
    VIDEO of walkaround and a few 0-60 tuning blasts: http://www.youtube.com/watch?v=OGT1lnQ1A9A
    This car is now for sale, see here: http://www.r3vlimited.com/board/showthread.php?t=209778
    I get alot of requests for info on this car. I've been collecting parts and chipping away at this thing for close to ten years now, my goal has always been to acheive race car performance in a naturally aspirated daily driver capable vehicle. Last time I had it on a dyno it put down about 220bhp but I have made quite a few improvements since then. I will update this thread as the project evolves or until a serious BMW or driving enthusiast buys it from me and I move on to another project.
    Body
    1984 BMW E30 323i - Delphin Metallic
    Late model plastic bumper and front valence conversion
    Hartge late model body kit incl: front spoiler, skirts, rear wing
    Startec tail lights
    Hella "smiley" head lights
    Chassis, Suspension and steering
    H&R Cup springs, strut inserts and shocks
    Suspension Techniques 22mm front sway bar, 19mm adjustable rear bar, polyurethane bushings, adjustable rear links
    Ireland Engineering reinforced rear sway bar mounts
    Custom rear subframe with adjustable camber and toe
    Poly subframe and trailing arm bushings
    Treehouse Racing offset control arm mounts/lollipops
    Mason Engineering front strut brace
    Custom rear brace that ties to rear swaybar mounts and shock towers
    E36 power rack swap (originally a manual steering car)
    BMW //M skid plate
    Drivetrain
    4.10 Limited Slip Differential
    Z3 finned differential cover with //M rubber mount bushing
    JB Racing 8lb aluminum flywheel
    Sachs OEM clutch and pressure plate
    OEM Getrag 260 transmission
    UUC short shifter
    Jaffster delrin shift knob
    Tires and Wheels
    Apex Arc-8, 17x8 track wheels, et25, 4x100
    Yokohama S-Drive 235/40-17
    VAC Racing wheel studs
    Brakes
    Front - Wilwood 6 piston w/ 11.75"(300mm) x .810" (21mm)vented rotors
    Rear - Wilwood 4 piston w/ 11.75"(300mm) x .810" (21mm)vented rotors
    Massive brake hats front and rear w/e-brake provision
    Custom made caliper brackets
    Stainless braided brake hoses
    Engine
    2.8 liter M20 "stroker"
    2.7 block bored +1mm, decked, align bored with ARP main studs
    325e 2.7 crankshaft, machined and balanced
    Custom forged Ross pistons, static comp ratio of 10.6:1
    Eagle 135mm H beam connecting rods with ARP rod bolts
    325i "885" cylinder head, fully machined and ported
    ARP Head studs
    Cometic MLS head gasket
    Schrick 288 camshaft
    VAC Racing adjustable cam timing gear
    PPM Race billet rocker arms, Porsche style adjusters
    Metric Mechanic stainless steel valves
    Metric Mechanic "beehive" progressive rate valve springs and retainers
    Hartge rocker cover
    Dbilas Dynamic intake manifold with independent 40mm throttle bodies and Dbilas plenum
    19lb per hour Ford Motorsport/Bosch injectors (21lb at 43psi)
    Nuke fuel rail
    Aeromotive adjustable fuel pressure regulator
    Vibrant bellmouth air filter adapter
    K&N air filter
    Mishimoto E30 M3 aluminum radiator, modified to relocate lower rad hose to opposite side
    Canton remote oil filter mount and filter housing adapter, plumbed with Aeroquip braided hoses
    Exhaust
    Hartge stainless steel headers into a custom "Y" pipe, 2 1/2" through Hushpower center section/resonator to a big Flowmaster rear muffler
    Ignition / Engine Management
    Megasquirt 2 V3 running v2.1extra firmware controlling fuel and spark
    Innovate LC-1 wideband o2 sensor and controller
    Wasted spark ignition using six S50 Bav Auto coilpacks mounted on custom rail
    Electric pusher fan controlled my Megasquirt
    GM temp sensors - air, water
    Jeep stepper motor Idle Air Control Valve, PID closed loop
    Innovate Motorsports gauge cluster mounted in BMP AC delete gauge panel, AFR, WT, OP
    Fluids
    Engine: Pennzoil SAE 25W50 GT Performance Racing Oil for its high zddp content
    Gearbox and Diff: Redline Shockproof Gear Oil
    more to come...
    "The bitterness of poor quality lingers long after the sweetness of low price is forgotten"
  • Dozyproductions
    • Jan 2007
    • 4682
    my god. This is built for business. Good show man, come to the e30 picnic with this!
    The only thing I would change is adding some sort of rear apron. Without a bigger one it really makes the car look higher and more naked than it is.
    • lbreevesii
      • Aug 2009
      • 412
      Very nice setup. What kind of power do you expect?
      I assume you're using light shockproof gear oil? The heavy stuff is like a liquid red crayola crayon. I've used it in well worn diffs before.
      I don't always wreck cars, but when I do I wreck them into trees.
      91' 318is S50 swap - The Black Widow
      • LJ851
        • 7919
        220 at the wheels or crank? What brand dyno? Nice work!
        Lorin
        The M30 is God's engine.
        • bimmerteck
          • 762
          Well Played! It looks like a lot of fun.
          • Erick
            Official R3V Drifter
            • 11169
            In before the circle jerk
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • BUDNUNTA
              • Apr 2005
              • 996
              That intake is business, well really the whole car
              haha
              We're out there in here.
              • gverelli
                • Dec 2008
                • 772
                Nice setup. Must be fun with the 4.10. Should get some vids up
                G.Verelli
                • red_e30
                  • Dec 2010
                  • 242
                  do you have some videos of how this beast sounds :p
                  my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
                  • structured
                    • 954
                    video preeeaase
                    • HarryPotter
                      • Jan 2010
                      • 3642
                      Those wheels are fucking incredible. Beautiful car.
                      John F. Kennedy
                      • frankenbeemer
                        • Sep 2009
                        • 2260
                        Originally posted by structured
                        video preeeaase
                        +1
                        Stunning!
                        Don't buy an e30
                        They're stupid
                        1989 325is Raged on then sold.
                        1988 325 SETA 2DR Beaten to death, then parted.
                        1988 325 SETA 4DR Parted.
                        1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                        • Nairb
                          • 1207
                          Just wet myself a little.
                          My 1991 318is Progression Thread
                          • BraveUlysses
                            • Jun 2007
                            • 3781
                            Please come to the picnic next year! Sweet car!
                            • Mlarsen
                              • 4082
                              hot damn, thats nice!
