Originally posted by E30 F34R
View Post
strokin' it. M20B31 build (finished!)
Originally posted by brutus87 View PostWAAAAAAY off topic, but nice wheels!
Are those euroweaves?
I have some euroweaves on mine that I want to refinish, and these look AMAZING.
Is that nogaro silver for the center?
Very clean! Nice job! What lens was used for the last photo?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
The 272 is a good choice if you want a mild cam without any headaches. You can run up to a 284 without getting springs etc, but you have to be a little careful (see towards end of post).
Originally posted by E30 F34R View PostFYI a real stroker it larger bore(bigger pistons) with shorter rods or bigger crankshaft. Since you already had the SETA it is just an improved topend. It is still a great build and motor!
DO NOT get a IE regrind
And you are going to have to buy upgraded valve springs to get over 7k with the cam.
Or just don't race it. On my brother's stroker build I am replacing the rockers with the beefy race ones to handle the higher RPMs. If you get the Schrick cam buy a IE cam adjuster gear. Only 100 bucks and helps dial in the cam =)
Thanks guys :)
Originally posted by Wh33lhop View PostThe 272 is a good choice if you want a mild cam without any headaches. You can run up to a 284 without getting springs etc, but you have to be a little careful (see towards end of post).
First problem has sprung up since the conversion. I was taking a couple pictures tonight and while I was moving the car around setting up shots I noticed it would really bog down for several seconds after firing it up. The problem only shows up when the car has been running for less than a minute between starts and would clear up shortly after, which leads me to believe it's a fuel issue. Pulled the vacuum hose off of the fuel pressure regulator and it was dry so I'm guessing it's a dirty/leaking injector. That's the problem with putting on a head from a less-than-ideal donor car; no idea what the history is like.
Anyways might as well post a pic:
The problem was a dirty injector I guess, ran some plain old Lucas injector cleaner and all symptoms disappeared.
Did a 3.73 lsd swap this last weekend, it's a worthwhile improvement over my 2.93 lsd. Made a few runs against a chipped '91 325i and beat it pretty good every time. :)
very nice man...you joined the club! I love your red e30. I'm gonna powdercoat my RX's white i think. But anyways, I have the IE 272 cam and it has worked flawlessly, no problems. dunno what they are talking about. I daily my car, you can hear the lumpiness of the cam still, but idles smoothly still. Has a good power band from about 3.5k-5.5k then it kinda falls off from there. I also have an adjustable cam gear i need to install as well. Also, according to my OBC. I still get about 22.5 mpg avg. I also did the 3.73 lsd swap.
What chip are you using? I had Dinan, was a piece of shit with the 2.7i, got a alpina b3 2.7 chip, its WAY BETTER! It idles at 1000 rpms tho. But with the dinan chip, i was getting only about 20 mpg.
I also plan on going from the stock injectors, to m50 injectors, (rebuilt/cleaned em, just gotta have time to put em in)
Whats the mileage on your car? I did this "stroker" at about 270k, and it was a nice refresh. I'm not at 286k. No problems what soever. Other than a couple speeding tickets/exhaust ticket lol. (With my cam + old exhaust, people asked me if there was a v8 under the hood)(SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
Originally posted by 88SuperETABD View Postvery nice man...you joined the club! I love your red e30. I'm gonna powdercoat my RX's white i think. But anyways, I have the IE 272 cam and it has worked flawlessly, no problems. dunno what they are talking about. I daily my car, you can hear the lumpiness of the cam still, but idles smoothly still. Has a good power band from about 3.5k-5.5k then it kinda falls off from there. I also have an adjustable cam gear i need to install as well.-Alex
Originally posted by 88SuperETABD View Postvery nice man...you joined the club! I love your red e30. I'm gonna powdercoat my RX's white i think. But anyways, I have the IE 272 cam and it has worked flawlessly, no problems. dunno what they are talking about. I daily my car, you can hear the lumpiness of the cam still, but idles smoothly still. Has a good power band from about 3.5k-5.5k then it kinda falls off from there. I also have an adjustable cam gear i need to install as well. Also, according to my OBC. I still get about 22.5 mpg avg. I also did the 3.73 lsd swap.
