strokin' it. M20B31 build (finished!)
  • Raxe
    • 5346
    Decided to do the 2.7i conversion on my Super Eta today. It's a nice improvement! Allow me to take you on a terrible photo journey:
    Started with an M20B25 from an '89 325i:
    Off comes the top half and into the solvent tank:
    Degrease (x4) and pressure wash repeatedly:
    Thoroughly dry off outside:
    Pull the old head off (shame, it's in fantastic shape):
    Install the new one (replacing the exhaust shields soon)
    Clean everything up and mess up the HID's in the process:
    Done! Took about 6 hours total but the whole thing went quite smoothly. The difference in power is immediately noticeable, it still has the exact same great low-end torque the ETA is known for but with the hard pulling horsepower the 325i offers. It's really the best of both worlds which is exactly what I was hoping for.
    So there you have it, r3vlimiteds newest 327i.
  • jaywood
    • Jul 2010
    • 4528
    <3
    Nice work
    • DTM190
      • Nov 2008
      • 1107
      No fucking around, just into it. Love it. Good job Raxe
      Originally posted by der affe
      first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
      if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
      • ubernasty
        • Jan 2009
        • 2749
        You made that look entirely too easy. Looked into that myself but got mixed up in all the different variants with eta rods/ i pistons/ m50 crank etc. etc. You just went straight eta bottom/ i head tho right?
        edit: meant seta rods... then again, i gave up trying to make sense of it all.
        someone needs to do a formal "how to do this shit right" sticky.... w/o all the bs mechanic wanna-be's and 15 yr olds inputs.... my 2c
        • Raxe
          • 5346
          Yup straight half-n-half. Used the ECU and intake from the 325i as well, it's pretty much plug and play. It's an 88 seta bottom end though, I'm not sure how much of a difference a regular e bottom would be.
          • Wh33lhop
            • 11705
            Not gonna cam it while you're at it? ;)
            paint sucks
            • Rhys
              • Jul 2008
              • 103
              The seta engine has reliefs cut in the top of the pistons for the valves. The 'regular e' bottom has flat top pistons.
              • Raxe
                • 5346
                I will actually, I'm going to pull the whole thing apart again in a few weeks and change the cam because it's starting to wear. Didn't know until we started doing the conversion but surprises are part of the fun :P
                I'm going to start researching it soon, but I keep hearing Schrick 272.
                Didn't know that, thanks!
                • HarryPotter
                  • Jan 2010
                  • 3642
                  This is technically only possible with the 88 seta. Doing so with a regular eta would give you very low compression, the car would be a slug. Good for turbo thou!!
                  Nice job dude!
                  John F. Kennedy
                  • Holland
                    • Nov 2008
                    • 7212
                    R3vlimited's latest and CLEANEST 2.7i.
                    Originally posted by DEV0 E30
                    • gverelli
                      • Dec 2008
                      • 772
                      x1000
                      G.Verelli
                      • F34R
                        sLaughter
                        • 12376
                        Schrick 284 and buy it from Vac motorsport. I have done my research already ;) 440.00 to your door. I have over 1k in the 885 head rebuild. Cam, springs, rockers(race), Schrick springs.
                        Good work, this looks clean and well done. FYI a real stroker it larger bore(bigger pistons) with shorter rods or bigger crankshaft. Since you already had the SETA it is just an improved topend. It is still a great build and motor!
                        DO NOT get a IE regrind, just saying because they are cheaper. Schrick all the way, double the price but worth every penny. And you are going to have to buy upgraded valve springs to get over 7k with the cam. Or just don't race it. On my brother's stroker build I am replacing the rockers with the beefy race ones to handle the higher RPMs. If you get the Schrick cam buy a IE cam adjuster gear. Only 100 bucks and helps dial in the cam =)
                        Instagram: @BWeissLeather
                        Current cars:
                        ~ '87 325 M30B35 swap
                        ~ '87 535
                        ~ 01 540 Msport 6spd
                        ~ '06 X5 4.8is
                        • Raxe
                          • 5346
                          Thanks for the tips! I won't be racing it, it's my DD so convenience/reliability is a factor. I was looking at IE's offerings. My dad bought the adjustable cam gear for his cabrio but hasn't installed it yet, so I'll have a chance to see how it works before pulling the trigger myself.
                          • Butler
                            • Nov 2009
                            • 1613
                            Fuck yeah.
                            -Nick
                            Originally posted by 87e30
                            First of all: calm the fuck down; second of all; cool story bro.
                            • freeride53
                              • 11972
                              That's a cool looking car you've got there, just sayin'.
                              1983 Peugeot 505 STI
                              1992 Volvo 240 Wagon
