Turning an E into an I..Car Progress Pictures
  • James Crivellone
    Head Janitor
    • 6305
    So Instead of taking over the gatherings thread about the e30 picnic I figure I would post my progress pictures in here.
    Each day counts as a full day, instead of random little weeknight days.
    Day 1
    Started in the early morning, and removed the engine, transmission, driveline, exhaust, dash, and misc electrical, also dropped off 325i single mass flywheel at machine shop, and sent intake manifold and valve cover in to get powdercoated.
    Engine Bay prior to cleaning, original 86 C101 Connector.
    Once the engine was out I worked a little bit on the interior, yanked the old original cracked dash, as well as a few of the harness's I am removing (Cruise, OBC, etc), also note the original factory ugly ass blue carpet.
    Quick Rattle-Can job on the engine block.. This is a 100% stock M20B25, nothing done to it except new gaskets, compression is 165 across the board and the engine has 120K miles on it. I realize the paint job is shit, however this motor is only temp seeing as my eta developed rodknock. I am still planning a Low Compression 2.8, and have another m20b25 which will be rebuilt for that purpose
    Clutch Disc after 10K miles, needless to say I am reusing this with the new flywheel
    DAY 2
    Today was carpet yanking day, and rewiring C101 with a 1991 325iA Harness.
    Working in a dirty engine bay sucks, so some scrub brushes and a pressure washer decided to attack my engine bay. Its a bit cleaner now.
    First I yanked out the heater box/harness, and removed the rest of the old OEM harness's I won't be using (IE Stock Stereo, etc). Here I am locating the tachometer feed for the new C101 Connector.
    Shot of the rear with no carpet, only one or two spots with surface rust.. did a quick sand and paint on those, should last awhile
    Snipping out the old C101 Connector
    Shot of the original C101 04/86 Connector
    I don't have pictures of the rewire portion, however I spliced all the wires into the 1991 C101 325iA connector and eliminated C104 from the car, did a quick electrical test and eveything came out green, hopefully the car will start with the new engine :)
    DAY 3
    This was a very busy day, today the clutch master cylinder was replaced, as well as the clutch return spring which snapped in half when the master was removed. Today also included the integration of the check engine light, and the m3 oil temp monitoring into the factory harness's. It appears OEM when you remove the cluster, hopefully no tech ever shits a brick if he sees that.
    Also on the pad was installing the carpet, heater box, dash, headunit, and center console, and test general electrical on the entire car. Minus engine of course.
    Picture of the rewired C101, you can easily notice the addition pins that BMW added vs the 86 C101
    Shot of the engine with head installed + accessories. Engine came out very well after a quick cleaning, other then the horrible block rattle can job nothing else has been repainted. Not too bad imho.
    Shot of the interior with dash and center console installed. Also modified the e30 m3 cluster once again, and installed the 7k tachometer face and 325i coding chip for the engine. You can also notice the AC Deletion/Cruise Control Delection.. As well as the lack of OBC thanks to the 316i euro center console.
    Closeup of the center console with headunit active.
    Doing a quick interior electrical check, only had one failure, the replacement blower motor does not work, will have to remove the cover and check for power motor side.
    Shot of the check computer freaking out with the lack of...everything. At least I know it works
    and finally for this post, another shot of the new carpet/dash/everything form the passenger side of the car.
    Tommorrow the rear amp rack gets built, the rest of the interior goes back together, and I troubleshoot the faulty blower motor.
    Another update tommorrow =)
    • 37834
    Amazing work James, my hat is off to you for the clean ass engine bay, interior is looking great. I installed the 316i center dash piece in my car aswell. Can't wait for more pictures, I love this shit.
    Grover Beach, California
    BimmerHeads.com
    • 88325isboy
      • Mar 2004
      • 1058
      looks very good. that engine bay is clean as hell good work man!
      '87 325 (Track Rat)
      '04 C5500 Wrecker (Work)
      '94 525i (Daily)
      '90 325i (R.I.P)
      H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
      • golde30
        • 11464
        awesome pics...yer eta is getting the full once over. how are u going to do the amp rack? i did mine to sit up against the rear seats. cant wait to see the finish product. :up:
        IG: @Baye30
        • ///M Powered
          • Jan 2004
          • 1109
          Looking great, nice job documenting your progress. Good luck with the work!
          • hamann318is
            • 3382
            Why didn't I buy an ETA? That car is one of my favorites.
            The BMW 318 is back. With a vengeance.
            • aschmidt
              • 457
              Man you've been keeping yourself busy! Keep us posted! :D
              -Adam Schmidt-
              1988 Zinnoberrot 325iS ::dead::
              1988 Bronzit 325iS ::sold::
              1991 Alpine 318iS
              • Digitalwave
                is a poseur
                • 6302
                WOW! Looking awesome James. Last summer you and I were both doing huge projects, this summer you are all alone :) The interior looks SO much better. What's up with that head unit? It looks huge, is it a 1.5 DIN that fits in a 1 DIN slot?
                RISING EDGE
                • tobybmw
                  • 453
                  awsome work. I really dig the euro panel where the old US OBC used to be.
                  • Court M3
                    • Jan 2004
                    • 6713
                    Looks like you have a nice project on your hands.
                    Continuous For Sale Thread
                    323i s50
                    • mikeedler
                      • 6707
                      looks like alot of work done. just one question, why did you change over the engine harness connector? I am in the middle of a 318 M10 swap, to a 91 325 m20 swap and have no plans on changing the harness, will I have to? didnt have to on my 88 M10 car I had before, plug and play. this one is a 86 though
                      • Il Duce
                        Non-Mod M42 Modder
                        • 5047
                        awesome work, i love your car more and more!!!!!
                        • James Crivellone
                          Head Janitor
                          • 6305
                          Thanks everybody for the comments. I'm really happy with how the car is progressing into a nice e30, while keeping it unique =)
                          DAY 4
                          Today was to wire in the amp rack, mount all speakers, install more of the interior, and do a full electrical test on the car and repair any issues.
                          I first mounted my two amps, and crossovers to a piece of wood covered in black carpeting, then using two large bolts I removed the ski hole and bolted the board to the trunk wall.
                          Here is the finished product, sans wire organization...once I get the car running I will be cleaning up the wiring, however currently it is 100% functional. I gave it a quick tune and damn does it sound good. Its far from an expensive setup, but its nicely balanced and provides me with plenty of noise.. (The M20 provides the real music)
                          A view of the entire rack, now with 100% messy wiring
                          Also got my flywheel in today, 14lb of pure fun
                          I next researched the faulty blower motor, which turned out to be a humerous issue, as the sunroof, windows, and power mirrors did not work either. A quick peak into the ETM, and bypassing a relay proved that without the engine harness connected, the K7 and K8 relays do not have a ground for the solenoid..so they will not trigger. I connected the engine harness and everything powered up. Weird wiring idea BMW.
                          Once that was out of the way, I installed the front speakers, and mounted the tweeters in the tweeter pods.
                          Next, I installed the new rear deck (will need to fill the premium speaker holes with something, not sure what the plan is yet) the rear seat, the side trim, door moulding, and front speaker grills.
                          Quick view of the rear seating arrangment.
                          With the stereo out of the way, and most of the interior, i concluded the day by painting the front pullys for the engine, and got them installed, I also cleaned up the thermostat housing, I will give that a quick coat of paint as some of it started chipping off.
                          Also sent the oil pan off to the welders to have a new threaded hole installed for the temp sensor.
                          That was about all for today, I'm very happy with the stereo, and the interior is really shaping up, at this pace the motor SHOULD be installed (sans valve cover and intake manifold as they are still at the powdercoater) by Wed or Thursday. Car should be then running the week after.
                          More to come later =)
                          • James Crivellone
                            Head Janitor
                            • 6305
                            The camera's white balence throws it off a little, however it is pretty clean.
                            • James Crivellone
                              Head Janitor
                              • 6305
                              Thanks TJ.
                              Yeah its an Alpine 7998 1.5 Din headunit that folds away in a really quirky fasion. 4V preouts and no internal amp, its really an awesome headunit for what I paid for it (around 300 bucks, used to retail for 800)
                              Here is a quick video I shot of it hiding away, its dark but you can see how weird the damn thing is. Hell it even pulls the volume knob down as it closes!
