Purchased 18.8.2011. Barely ran. Rough. Shot drive-line. Cut springs and stock, shot shocks. Bad camber. Horrible paint. Falling apart. 50% complete interior. When I cracked the oil drain plug to change the oil, as the first thing I do on any new acquisition, nothing came out. Nada-- not even a drop. Let that be a sign of how this was kept.
Here's what it looked like when I picked it up:
came with a bajillion stickers. even had a wiper removed to add more (quality) stickers.
The guy I got it from has it on stock shocks/cut springs. AND JUST LOOK AT THIS INTERIOR! >:(
Currently:
(as you can see below, I am no photographer-- sorry about the photo quality!)
2.7i >:}
I tore the engine down, cleaned it a bit, did the conversion with an extra set of hands (that tube! you know the one!), replaced vital parts (timing belt, water pump, etc) and now it runs beautifully. Sounds great, feels great, and gets great MPG (25-28 unless I'm feeling a bit zealous).
--Mods & replacements--
Suspension & Brakes:
Bilstein Sports
Ireland Engineering Stage 3 Springs
New sway mounts and links (OEM)
New OEM brembo vented blanks
Stop-Tech F+R Pads
Stainless Steel Lines
Power:
2.7i 885 head on ETA bottom
Full Motronic 1.3 harness swap
19# Ford Motorsport Injectors, Quad-Pintle
Motronic 173 Fully Tuned by SSSquid.com
K&N Filter in stock airbox
OBX headers
Fullboar Exhaust with high-flow cat
Innovate LC-1
Exterior:
Bumper Tuck
14" weaves (new wheels in the waiting)
US ellipsoids
Euro Grills
Misc replacements and mods:
Continental Timing belt at 170k
Metal Impeller Hefi Water pump at 170k
Condor motor mounts
Condor tranny mounts
Condor RTABs
OEM CSB
OEM slave cylinder
replaced missing hood latch handle
OEM hood latch cable
OEM throttle cable
OEM shifter seal
OEM fuel pump
new distributor and wires
black sports seats
replaced missing knee bolster
-Custom and Maintenance
corduroy center console
custom made wooden knob from ChefSkinny
Full synthetic tranny/diff fluid
20w50 rotella
Garagistic ODO gears + shifter bushings
Completely reupholstered interior, tan to dark grey/black
premium speakers
B25 tach conversion
disassembled and sand-blasted clean intake manifold
new front hubs
Plans:
Euro grills
IE adj. sway bars
RX7 Brake upgrade
Maybe in the future go FI. Have thought about it seriously and would rather hold off for now however and accumulate the correct parts slowly and surely.
Currently:
2.7i >:}
Bilstein Sports
Stop-Tech F+R Pads
Power:
OBX headers
Innovate LC-1
Exterior:
Bumper Tuck
US ellipsoids
Euro Grills
Condor motor mounts
Condor RTABs
OEM CSB
OEM slave cylinder
OEM throttle cable
OEM shifter seal
OEM fuel pump
black sports seats
20w50 rotella
premium speakers
B25 tach conversion
new front hubs
Plans:
Euro grills
IE adj. sway bars
RX7 Brake upgrade
and then i'm like
