Been doing a little bit of work. I tore the block apart, polished my crank, checked so called fresh bearings (were actually new, but one main bearing got nicked so a new new set will be installed) rod bearings good. Cleaned the pistons up a little bit and re-indexed the rings. Block should be back together fairly soon. Took the head home, and started putting a couple things on it. Going to be using all new fasteners where visible. Pictures of pistons/crank/block are before I did anything to them. Block was re-honed
And I still need to get some new bolts/washers for the fuel rail as you can see they are still old/hideous
And Zeus, he's already 30+ pounds
He likes to pose for the camera
