I like this car a lot. Well done :thumbsup:
A formal introduction to "Crunchy Bleach"
I don't remember where the velocity stack was found... I do know that it was initially silver.
The tires are really good as far as grip and handling. You gotta fight with them to keep sliding.sigpic
85' e backSTABBATH
Need a good mechanic/fabricator/performance shop in SoCal?
http://www.r3vlimited.com/board/showthread.php?t=155404
Castro Motorsport
12600 Sherman Way, Unit C
North Hollywood, CA 91605
818-765-3606Comment
What did you use to mount the seats? I am looking to pick up some.
BTW your car is sick, I have loved it since the Just Stance feature a while backComment
this car may be my fav metal bumper. i wish i had those rear quarter panels on mine!Originally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
I really hate..
how I really love this car..Comment
Engine:
-Recently rebuilt 2.5 "i" motor
-ARP2000 head studs
-MLS oversized head gasket to lower compression
-New over-sized Mahle pistons and rings
-Schrick turbo cam
-BMP adjustable cam gear
-Ebay top mount turbo manifold, which Chris rewelded for strength and reliability
-Garrett T3 60-1 journal bearing turbo: A/R 60, 0.63 exhaust housing
-44mm v-banded waste gate
-HKS blow off valve
-38# Lucas injectors
-eBay intercooler
-Intercooler piping: 2.5" hot side, 2.75" cold side
-German Engineering M20 silicone intake tube
-German Engineering rebuilt and shaved throttle body, with flipped butterfly and m50 throttle position sensor
-German Engineering built and fully tuned Megasquirt stand alone ECU: Microsquirt daughterboard and DIY PNP
-Castro's custom 2 piece, fiberglass intake box - Turbo Version
-3" custom, mandrel bent downpipe
-3" custom, mandrel bent oval turbo back exhaust
-Custom Dr. Pepper 6-pack oil catch can
-Getrag 260 trans
-13 lb lightened flywheel
-Gripforce stage 2 clutch and pressure plate
A big thanks to Nigel (einstein57) from German Engineering for his awesome products, and for building and fine tuning the Megasquirt system!
Suspension:
-Ground Control coilovers
-Front adjustable Konis (shortened struts)
-Rear custom shocks with German Engineering extended shock mounts
-Ireland Engineering sway bars (22' front 19' back)
-Fully reinforced subframe by Castro Motorsport
-Vorschlag camber plates
-95' M3 rack and pinion
-M3 sway link conversion
-All polyurethane bushings
Rolling:
-ESM 002 16x9
-Falken azenis 215/45/16
-Stainless steel brake lines
Interior:
-Gutted and tar free
-NRG steering wheel
-NRG quick release
-Momo hub
-NRG fixed seats
-Schroth harnesses
-Castro Motorsport short shifter
-"Custom" dash
-BMWpedals.com pedals with custom dead pedal
-AEM analog boost and afr gauges in German Engineering cluster
None of this would have been possible if it wasn't for Chris and Castro Motorsport's open minded approach to everything.
Hands down the most sincere and talented mechanic/fabricator out there.
Castro's Smog and Repair 818-765-3606Comment
