Its alive !! My e30.
  • Austin
    • Apr 2005
    • 9
    Finally got the damn thing put together, modified, started, idling and stopping. Took it to the car wash and found out that just using the power wash I can blast off most the first layer of paint. Previous owner did alot of shitty work on it. Second layer of silver paint is coming thru so I need to repaint in near future. Gonna do gun metal grey kinda color.
    Also came with those horrible DTM 3.5" tips which will be chopped off and new tips welded on. Anyone have a welder ? Muffler doesn't sound to bad its pretty deep.
    Future work:
    2 new low beams both are filled with water
    Tuck front and rear bumper
    Cd player has nothing now
    Momo Steering wheel current one sucks
    springs/shocks and drop it
    new paint and painted bumper surrounds
    paint rear yellow turn signal red
    new window tint
    Its main purpose is to work till I get the motor swap worked out. Currently leaning towards M52 aluminium head and aluminium block with OBD1 intake manifold, 3.5 HFM, S52 headers, S52 cams.
    Click here for list of mods.
    1992 318is - 265,000 miles - 120rwhp
    1986 325 - 235,000 miles
  • ColdAccord
    • 5926
    on early cars, euro bumpers >*
    Originally posted by blunt
    • Stu Mc
      • 4083
      Austin, I think I've chatted with you in some M42 threads over on BF.c, how is your 318 doing?
      Nice E30, polaris is one of my favorite colors. Euro bumpers would be the tits on that car if you can a) find used ones or b) afford new ones
      • Digitalwave
        is a poseur
        • 6298
        Now there's a pile. Perfect daily driver.
        RISING EDGE
        • KevRC4130
          • Nov 2004
          • 332
          That's pretty gross, but judging by that beautiful E36, I trust that we will soon have yet another hot E30 in our presence. Those wheels look great, and would be really hot if you had them powdercoated/refinished.
          • rede30
            • 4697
            it needs some work but i really hope your plans for it get done. should be really nice. goodluck
            Dustin
            • Austin
              • Apr 2005
              • 9
              Thanks for the comments. I'll look into euro bumpers not sure if I've ever seen any still new to e30 stuff.
              The 318 is still running great with 260k on the motor and tranny and no rebuilds yet. I consider the 318 pretty much "done" and the e30 is ready to begin.
              Head lights, paint, susp, engine, seats....everything will be changed till it has a smooth clean look for now its "ruff rice" as I call it. Referring to the exhaust tips.
              Think I'll actually go darker on the color more of a grey so not a hard contrast between body color and rims. The rims are 16" TWS hockenhiems that I had repaired and powder coated black only missing the center cover over the lugs I forgot to put on before taking the pics.
              I've already started rebuilding the suspension ordered control arm bushings, rear shock mounts stuff like that.
              Anyone have pics of grey or silver cars with black rims ? Or just grey/silver cars that look clean ?
              • Austin
                • Apr 2005
                • 9
                Forgot to list things I've already done:
                16" Hockenhiem rims repaired and powdercoated black w/ clear shot on top for gloss
                tossed the flat metal shifter upgraded to new aluminum shifter all new bushings and e36 m3 shifter.
                New "used" tranny w/ royal purple syth fluid
                New tranny bushings
                New "used" drive shaft with new center support bearing
                Flexdisc w/ new bolts
                New tranny bolts
                Removed exhuast replaced rubber hangers and all gaskets with new bolts
                NGK plugs
                plug wires
                distributor cap w/ rotor
                Timing belt w/ tensioner
                Replaced all the rubber fuel hoses w/ new clamps
                Fuel filter
                New slave cylinder
                new clutch
                pilot bearing
                rear main seal
                throw out bearing
                resurfaced flywheel
                325i window switches that light up
                new shift boot
                new e36 leather 5speed shift knob
                PBR metal master brake pads w/ sensors
                New cone air filter
                New air intake boot
                Clean throttle body
                New vaccum lines
                new hose around idle control valve
                Clean idle control valve and tested
                degreased motor
                flushed radiator filled 1.5 gal water .5 gal antifreeze and water wetter
                New belts
                new parking lights had all 4 smoked
                smoked the blinkers installed in the fender
                mothers back to black on the outside plastic/rubber
                cleaned conditioned interior which is in great shape
                new battery
                Ordered about to change:
                front control arm bushings
                rear shock mounts
                front sway bar links
                rear sway bar links
                2 new sealed low beams current ones filled with water.
                Oil pressure sender
                adjust valves
                Gonna keep rebuilding suspension before I drop it H&R/bilstein. Its alot of money to spend on a ETA but I dont like to half ass stuff and want a good running car while I rebuild it and research/ learn about e30's. In the end it'll be awesome.
                • Digitalwave
                  is a poseur
                  • 6298
                  See my sig for sterling silver with black rims.
                  RISING EDGE
                  • demlotcrew
                    • May 2004
                    • 297
                    Did you forget to take the axle stands out while taking the pic?
                    A
                    Andrew AT E30zone.co.uk | H23-is | S14
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      Ouch, you spent money on refinishing TSW's? That'll go to waste pretty soon.
                      • Austin
                        • Apr 2005
                        • 9
                        Rims came with the car so basically free and I worked for a BMW dealer in the parts department at the time so I didn't spend alot. ;)
                        • Mystikal
                          • 9602
                          Good stuff. So all that maintenance stuff was done with BMW parts?
                          • Austin
                            • Apr 2005
                            • 9
                            Yah BMW parts, but few things I picked up other places like wipers crap like that.
