Abit's 318iA m20b30 + pssycat cam and more...
  • 88SuperETABD
    • Apr 2009
    • 911
    #106
    in your acceleration video, your cars idling at 1500 rpm? or was foot on gas??
    Great work otherwise. LOVE IT!!!!!!!!!! Im using a m52 crank in my new motor too :)
    Wish I had places around where I lived that I can go hoon around like you.
    Keep up the good work and updates :)
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
    • abit
      • Jul 2011
      • 420
      #107
      I was already slowly driving :)
      What rods and pistons you are using?
      http://instagram.com/mundieriss
      my 88' m20b30 HERE!
      • Link
        • May 2012
        • 834
        #108
        I like this car a lot. Still looks clean even with mismatched wheels. Keep it up! Have you thought about running some euroweaves in the front to create a "staggered" look?
        View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
        • abit
          • Jul 2011
          • 420
          #109
          actually, before I got 4 more RZ's, I thought about that (like that blue cabrio also here, like It a lot), but now will stay with all the same size :)
          my 88' m20b30 HERE!
          • abit
            • Jul 2011
            • 420
            #110
            ok, got this brakes master cylinder for my new brakes servo unit, it's from e34 with ABS, how to connect brake lines to this? :D which hole is for front and which for back's ? I don't have ABS on my e30 :)
            my cylinder is exactly the same how in pic.
            my 88' m20b30 HERE!
            • abit
              • Jul 2011
              • 420
              #111
              ok, little update..
              cleaned up pistons.. actually they r already assembled and putted in block (no pic yet)
              then changed pilot bearing, that was a hell of a job to get old one out
              time for the brakes...
              to this, vacuum servo and main cylinder from e34 2,5tds
              also started working on cylinder head, so valves cleaned up..
              ok enough, more progress soon
              my 88' m20b30 HERE!
              • abit
                • Jul 2011
                • 420
                #112
                started to work on cylinder head..intake...
                my 88' m20b30 HERE!
                • abit
                  • Jul 2011
                  • 420
                  #113
                  head almost ready for assembling. lil bit ported more like just polished.
                  and engine block back in
                  my 88' m20b30 HERE!
                  • el bimmer
                    • 900
                    #114
                    Looking good!
                    • 88SuperETABD
                      • Apr 2009
                      • 911
                      #115
                      Eagle Rods, and custom pistons made by Paul Burke. 8.5:1.
                      • abit
                        • Jul 2011
                        • 420
                        #116
                        not much has been done, just assembled head...
                        new valve stem seals
                        then all the valves came in..
                        bloody Mary :-D
                        all assembled
                        and hey hey, What spark plugs to use in m20b28 with m50 management? same Ngk's as on stock m20b25?
                        my 88' m20b30 HERE!
                        • abit
                          • Jul 2011
                          • 420
                          #117
                          BRAH :mrgreen:
                          my 88' m20b30 HERE!
                          • NJ2.5rser
                            • May 2013
                            • 527
                            #118
                            Did your crank have the trigger wheel on it and if so did you have to remove it?? Any issues with the counterweights hitting the block? I just installed the crank and noticed it was hitting the block. Ive heard some people have run into this problem and some do not.
                            Car looks like its coming along great!
                            • abit
                              • Jul 2011
                              • 420
                              #119
                              Seems like your crankshaft is from double vanos m52b28, and it have bigger counterweights. Yes you can remove trigger wheel and if possible grind some material from block, but I seen that others remove material from crank counterwights and balance it after all.
                              My crankshaft is from single vanos m52b28 so without trigger wheel and with smaller counterwights so it fits straight in.
                              my 88' m20b30 HERE!
                              • whodwho
                                • Jun 2008
                                • 1547
                                #120
                                Just a FYI for future builds or people following yours, valve seals should be installed after the valves are in or you chance cutting/damaging the seal from the keeper grooves when inserting the valves.
                                There should be valve stem condoms in the gasket set that you slip over the valve stem and then slide the seal over it.
                                My M20 Frankenbuild(s)
                                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
