Abit's 318iA m20b30 + pssycat cam and more...
  • NJ2.5rser
    • May 2013
    • 527
    #121
    Originally posted by abit
    Seems like your crankshaft is from double vanos m52b28, and it have bigger counterweights. Yes you can remove trigger wheel and if possible grind some material from block, but I seen that others remove material from crank counterwights and balance it after all.
    My crankshaft is from single vanos m52b28 so without trigger wheel and with smaller counterwights so it fits straight in.
    Yup you were exactly right. I wound up machining the block and no it's spins perfect with enough room for anything to stretch a little.
    • DzusFast
      • Dec 2013
      • 42
      #122
      Originally posted by ABIT
      and hey hey, What spark plugs to use in m20b28 with m50 management? same Ngk's as on stock m20b25?
      Yes, same coil, same distributor cap same cylinder head right? and M50 management's dwell angle is approximately same. I would feel confident running the plug BMW accepts with that stock head.
      While I'm on the couch eating pizza, abit's building his car! (I must be getting old.)
      Love the thread, simply awsome pics/gifs and I can hear the European accent in the writing....WAAAAY TOOOO COOL!!! (I can imagine:"After paint car we drive to local ghetto for snapshot and beer, yes?") ...Definitely nice work abit, keep it up dude!
      Diggin' the "sacrificial" removal of headlamp for cold air abduction...ahhhh, the possibility of a few more HP's. Must be in our blood.
      it's an E30.......sigpic
      Originally posted by D...
      How the hell did I miss this? Must be cause I was reading some guys Cavalier build.
      • abit
        • Jul 2011
        • 420
        #123
        actually all ignition system is different on m50 than m20, but i stick with stock plugs
        word... today's picture :mrgreen:
        all seems ok, only it won't start
        looks like fuel is coming, there is spark, but it does not start, just fires only 6th cylinder, and later 5th came in too :mrgreen: don't no where to start finding problem, it was late and I gave up, will try later :)
        DzusFast, of course after painting, we made some pics and later we drank some beer, mmm :D
        ..and we all know that this CAI almost makes no difference, but it makes car look mad, because racecar
        http://instagram.com/mundieriss
        my 88' m20b30 HERE!
        • CubbyChowder
          • Mar 2012
          • 1488
          #124
          Love this build, fresh zinno always looks so good
          --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
          --Golden Boy E30 Build Thread-- (sold)
          • abit
            • Jul 2011
            • 420
            #125
            ahh, almost forgot, already found out one thing that is wrong, timing belt is not matching both marks, so I will fix that and hope It starts :)
            my 88' m20b30 HERE!
            • DzusFast
              • Dec 2013
              • 42
              #126
              One question (someone correct me if wrong) single vanos M50 EMS runs a "Cam sensor", giving the COPs timing. If your only firing one hole, it makes sense might be lacking important component.
              COPs are also a 'hotter spark' so do a plug check after a few thousand miles and see if they're running hot (Broken porcelin) - listen for detonation too.
              And mount those COPs (Coils), I forget if the secondary winding negative comes from them being bolted up or not. (Primary power and trigger is from the 3 wire plug to the coil)
              YEAH!!!
              • abit
                • Jul 2011
                • 420
                #127
                yes, m50 non-vanos also have cam sensor, but it runs fine without it.
                this all mess is just for firing it up and see what is what, so later it would be all mounted and beautiful :D
                ...and each coil had connected negative wire (not in pic) :)
                my 88' m20b30 HERE!
                • abit
                  • Jul 2011
                  • 420
                  #128
                  HE'S ALIVE!!! YEEAAAH BABY
                  troublemakers were my new fuel injectors what I bought, changed them to my old m20 injectors and it started right up :)
                  my 88' m20b30 HERE!
                  • abit
                    • Jul 2011
                    • 420
                    #129
                    Hey, maybe somebody can help me to recognize connector on m50 engine harness, It have brown/yellow and brown/violet wires
                    edit: seems like its for coolant temperature sender to instument cluster.
                    and if all non vanos m50's does have intake temperature sender?
                    answer: yes, they have
                    :D
                    edit2:
                    how it looks now
                    my 88' m20b30 HERE!
                    • abit
                      • Jul 2011
                      • 420
                      #130
                      finally it's running, done some little test drive, feels great :pimp:
                      of course not everything is done, but now looks like this.
                      my 88' m20b30 HERE!
                      • e30sky
                        • Aug 2013
                        • 106
                        #131
                        mods
                        great work bro...........what is the purpose of the mods u did with the coil pack there on the valve cover?
                        • abit
                          • Jul 2011
                          • 420
                          #132
                          mm, I have m50 management now, so I had to use coils, thats all
                          HOW ABOUT THIS?
                          my 88' m20b30 HERE!
                          • abit
                            • Jul 2011
                            • 420
                            #133
                            oh and first start
                            my 88' m20b30 HERE!
                            • abit
                              • Jul 2011
                              • 420
                              #134
                              Hey, how to get 3.5 bar fuel pressure regulator on m20 engine, is possible to bolt on regulator from another car? (porsche 944?) or maybe its possible to fit fuel rail from m50 engine on m20?
                              my 88' m20b30 HERE!
                              • whodwho
                                • Jun 2008
                                • 1547
                                #135
                                I have a 3.5 bar FPR for a M20 rail, let me see if I can find the part number for it.
                                My M20 Frankenbuild(s)
                                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
