Abit's 318iA m20b30 + pssycat cam and more...
  • abit
    • Jul 2011
    • 423
    #256
    As I noticed before, participated in some local forum track day, damn, so much fun :D
    preparation ;D
    good enough
    first mounted some shitty rubber and we are ready :D
    so... some driftin
    and later some time attack
    nice race/stance :D
    @ afterparty with some old bangers :D
    something like that, enjoying last season weeks :( :D
    http://instagram.com/mundieriss
    my 88' m20b30 HERE!
    • litu
      • 848
      #257
      Dam that red one looks cool...What is that white e30, looks interesting :)
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
      • abit
        • Jul 2011
        • 423
        #258
        kinda winter started here in Latvia, so car gone to winter sleep
        lil bit snow :D
        buut then, incidentally bought new wheels :D
        Intra's 16x9
        and actually I'm very pleased
        In life looks even better...of course
        but otherwise still banging with compact
        Stay tuuund
        my 88' m20b30 HERE!
        • abit
          • Jul 2011
          • 423
          #259
          here we go again
          let's stroke dat shht lil bit up :devil:
          dayumn, just noticed, my post count... right there i'm going :D
          my 88' m20b30 HERE!
          • efficient
            • Feb 2012
            • 3312
            #260
            It's going to be a 3.0 m20?
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              #261
              84mm crank with ~86mm bore?
              or 89.6mm crank with 84mm bore?
              Originally posted by priapism
              Originally posted by shameson
              • abit
                • Jul 2011
                • 423
                #262
                yes, it's going to be something about 3 liters m20
                90mm m57 crank
                135mm m52/m54 rods
                and m54b25 pistons
                84mm bore
                my 88' m20b30 HERE!
                • mila325
                  • Sep 2015
                  • 82
                  #263
                  Got tired of the 2.8? Might I suggest going ITBs if you want to stay N/A? Would give a GREAT boost of power with the extra stroke.
                  • abit
                    • Jul 2011
                    • 423
                    #264
                    yes and no... of course, let's be honest, everyone wants more and more poweeer :D
                    but in reality engine started to make piston slap while cold, i believe 2 years already now? so I decided that I should mend it, and make something different :)
                    yea, i thought about that many times, but it's not cheap upgrade at all, maybe some day there will be ITB's, but that's not in nearest plans for this car.
                    my 88' m20b30 HERE!
                    • mila325
                      • Sep 2015
                      • 82
                      #265
                      So going for a cheap 3 litre stroker? Let me know how it goes! Any idea on how long until done? :D
                      • abit
                        • Jul 2011
                        • 423
                        #266
                        Yes Sir!
                        for sure, errm, now block is disassembled, I hope tomorrow I get crankshaft and then some measuring, machining, aand putting together, as fast as possible, as always :D
                        my 88' m20b30 HERE!
                        • mila325
                          • Sep 2015
                          • 82
                          #267
                          Yes Sir!
                          So before the end of the year? ;) I want to see burnouts with all the extra torque! Any plans outside of the motor?
                          • abit
                            • Jul 2011
                            • 423
                            #268
                            that's impossibruu :D I believe first start could be about @ february.
                            many things should be fabricated, made to fit etc.
                            also thinking about 240mm clutch, using m30 disc and m57 pressure plate, but that assembly is thicker than m20 assembly, needs ''longer'' throw bearing, don't know, maybe from e21 or smthng?
                            also some while ago I thought about m3 fenders and bumpers (fiberglass), but then there is problems with MOT, will see..will see :)
                            my 88' m20b30 HERE!
                            • abit
                              • Jul 2011
                              • 423
                              #269
                              dayumn, almost forgot, every years acceleration video :D
                              this time pretty crappy quality..
                              compare to last year, just lil bit different exhaust, adjusted cam(in both thank's for advices goes to Digger ), and different differential ratio
                              my 88' m20b30 HERE!
                              • abit
                                • Jul 2011
                                • 423
                                #270
                                Of course, first test assembly, then measuring :D
                                bolted in one piston, aand it's not below deck, but above, fail...
                                later done some measurements and that actually should be like that :D
                                45 + 135 + 27.8 = 207.8 (if we believe that m20 block deck height is 206.7 or 206.2?)
                                means about 1.1 or 1.6mm over deck, in reality something closer to 2mm's, of course that's not precise measuring, but for test fitting, it's ok :D
                                so there is two alternatives:
                                1. shave off material from piston
                                2. 130mm rods
                                as we know these are one of thinnest 84mm pistons, so there in not much material from top compression ring to piston head..
                                what could be the smallest distance piston to top? so it won't overheat top rings and piston won't crack details out :/
                                i believe 1mm off, could be enough for me
                                if now its something about 5mm, what I think already is really low
                                I don't tried second (130mm rods) thought but i believe that its not actually possible because of crank counterweights could hit piston skirts and m20 rods maybe won't rotate in block
                                aaand so big stroke and short rod on 84mm bore could be not best idea, right?
                                some comparison
                                m54b25 m52b28 late m20b25
                                my 88' m20b30 HERE!
