Abit's 318iA m20b30 + pssycat cam and more...
  • abit
    • Jul 2011
    • 423
    #271
    ok
    fiiiinally got parts from machine shop, dayumn 3 months to make crank complete to fit in..
    ok, assembled 1 piston again, now with timing belt etc
    piston 2 valve distance looks veery promising, I'm happy
    intake about 5+mm, exhaust ~4.5, so very good..
    but, not so good about piston to head clearance :D
    mathematically
    206.2+2.05=208.25
    45+135+27.8=207.80
    208.25-207.8=0.45mm and as we know head gasket will be thinner when head will be torqued
    this is how piston looks @ TDC with used 1.75 HG
    something like this with clay
    I will use 2.05 thickness HG, but that's pretty minimal more than this
    so what should I do? thinking of, machining liittle bit off piston edge, what you think?
    and how much is normal to shave off oil pump shaft?
    1..2 mm ?
    that's all for this moment..
    http://instagram.com/mundieriss
    my 88' m20b30 HERE!
    • digger
      • Nov 2005
      • 6196
      #272
      depends on rods but D18mm near where the rod should goes by works with m52 style rods and many aftermarket. you only need a local scallop
      • abit
        • Jul 2011
        • 423
        #273
        ok, I will check it. and Im using m52 rods, yes.
        but Digger, what you think about that small piston to head distance and machining piston edge off lil bit?
        my 88' m20b30 HERE!
        • digger
          • Nov 2005
          • 6196
          #274
          You should machine them. It's only going to be close near the edge. If you add the coorect chamfer style around the circumference you might even get some squish to.
          • zwill23
            • Jul 2015
            • 615
            #275
            One of my favorite threads for sure.
            Also, for the record... I use this gif all the time:
            • abit
              • Jul 2011
              • 423
              #276
              [IMG]https://i.makeagif.com/media/1-11-2016/V2mi_U.gif[IMG]
              oh, nice to hear :)
              dayumn, that was so long ago :D
              also, while I was waiting for engine parts, finally changed o rings for heater
              ..what you do when your work light breaks?
              you improvise..
              my 88' m20b30 HERE!
              • abit
                • Jul 2011
                • 423
                #277
                sooo, cut some material from pistons
                1 x 5 mm off from piston edge
                now it looks more promising :D
                so now it should be about 1,+ mm distance piston to head
                also shaved oil pump shaft :D
                so with distances between parts everything looks promising, but
                CR is pretty high, 11,4:1 but I hope e98 + management tuneup will help to run without detonation :D
                stay tuund
                my 88' m20b30 HERE!
                • digger
                  • Nov 2005
                  • 6196
                  #278
                  gonna run thr 1.75mm gasket?
                  did you check the rod to shaft clearance after machining it?
                  • abit
                    • Jul 2011
                    • 423
                    #279
                    no, I will use 2,05mm HG
                    yes, abooout 3mm. sticked clay round the shaft :D
                    my 88' m20b30 HERE!
                    • abit
                      • Jul 2011
                      • 423
                      #280
                      :D
                      so after got all parts modified it was time to put it all together :D
                      assembled block
                      bought oil scraper
                      but it needed some machining done to fit :D
                      at start, already some bits cut off
                      and my version for 90mm crank :D
                      I always thought that I have ''light'' one of m20 flywheels, but seems like i was wrong :D
                      so, took this one of my mates e28 m20b20
                      so next...let's put it in
                      we put block in, everything looks ok, rotated etc, torqued down gearbox with engine, tested clutch...its ok, gone back to engine...aaand it wont rotate :D
                      just liiitle bit unscrewed gearbox bolts and it started to rotate, dayumn..block out :D
                      gearbox primary shaft was pressing crank forward, so it stopped in axial shafts
                      no big deal, cut 5mm's off gearbox primary shaft, and everything is fine :D
                      beauty of m20
                      and all in one piece
                      the view of front pulley
                      used 12.9 bolts from market, torqued as m57 spec 40nm +60 +60degrees, but seems like they are stretching, so I will replace them with shortened old head bolts
                      and of course...first start video
                      coils was not fully plugged on, so engine was not working as it should,
                      later fixed that problem
                      done some test drive, feels pretty nice :D
                      only it needs new tuneup, seems like it wants to detonate on more load, so driving pretty safely now.
                      HG collection + 2 out of photo
                      my 88' m20b30 HERE!
                      • digger
                        • Nov 2005
                        • 6196
                        #281
                        looking good.
                        for the bolts torque to angle changes with length so if the bolts are shorter length then you cant torque the same amount. are OE bolts from m57 too long or too short?
                        what crank scraper is that? ishihara johnson?
                        yeah makes sure you get it tuned nicely i think it will be very sensitive to knock (high CR and different dome). what ECU do you have looks like you are running a MAF?
                        • abit
                          • Jul 2011
                          • 423
                          #282
                          looking good.
                          thanks.
                          mm, yes, you are right, I actually didn't thought about that.
                          OE M57 is M10X86, mines M10x100, that means max torque to these bolts should be bit less, right?
                          really don't know, bought it used from forum.
                          yup, guy who tunes my car knows what to do with these bosch managements. his car has m50bxx twin turbo with the same m50 nv management(of course there is some modifications done in ecu, but still) and makes about 800hp, already few seasons driving with this setup, only now changed management to Russians Abit aka Corvet ecu.
                          As it was before, I use complete m50 non-vanos management.
                          my 88' m20b30 HERE!
                          • abit
                            • Jul 2011
                            • 423
                            #283
                            and some not so good news
                            my 88' m20b30 HERE!
                            • digger
                              • Nov 2005
                              • 6196
                              #284
                              with the different gear and damper it looks like it needed longer bolts to get the proper thread engagement? after you fix the threads with helicoil or similar i would just torque it upto a torque value Nm appropriate for a M10 rather than a torque angle
                              yeah i forgot you had M50 management
                              • abit
                                • Jul 2011
                                • 423
                                #285
                                oh.. this is an head bolt, not from damper :(
                                dont know why this happened. seems like that was that sound I heard after second start up. this happened when engine was already turned off, just standing. all head bolts torqued to 90nm last stage, these are 12.9 hex bolts. i know many others who torque them to theese nm, so, again, problems...
                                my 88' m20b30 HERE!
