OMG ITS T3H BODYROLLZ!!!!111evelen
  • rwh11385
    lance_entities
    • 18403
  • motorprestige
    • Oct 2004
    • 788
    wow, what kind of suspension are you running?
    "Having won more road races than any other model in history, the E30 M3 is considered by many to be the world's most successful road race car." - Simply put, E30s kick ass.
    • PeaveyBassist
      • Sep 2004
      • 3511
      He has Ground Control Coilovers. Dunno what spring rates though ;)
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • bimmer8604
        • 3017
        what the heck? you take out your swaybar? LOL.
        kyle
        1988 M3, 97 840, 99 XJ
        DILLIGAF
        • rwh11385
          lance_entities
          • 18403
          300/475#. No rear sway. Sticky Azenis 205s.
          I love the setup for HPDEs. (see sig, on the smoother track, car has a lot less roll than the choppy Auto-X, and Auto-X takes a backseat to roadcourse) Both me and my friend/co-driver (#85) agreed the body roll wasn't really problematic or intrusive, but only looked funny and gave feedback. (feeling the weight transfer and shift is actually pretty good for me learning at the track)
          475/650 rates, m3 front swaybar endlinks, and the rear bar back on will be a fast car..... once i know how to drive it, that is.
          • bmwm3n528
            • 3654
            I was told the same thing from Billy Revis, mentioned they're really a lot of fun w/out the rear sway.
            Trevor Ely
            '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
            '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
            • Sean
              • 5793
              Car looks pimp, Robert. lol
              I should try removing my rear sway this summer...that'd be sweet! :)
              - Sean Hayes
              • alex
                • 2024
                Robert is hooked on auto-X!
                Pics look great!
                Stiff front bar would help with body roll.
                • rwh11385
                  lance_entities
                  • 18403
                  nah Sean it's still back there. I just unhooked it. takes 10 minutes either way so who cares.
                  Alex, hahaa. not really. It's just more seattime...... ;) I'm a roadcourse junkie really. But Grissom is an AMAZING venue though.
                  The m3 endlinks and tabs to use them would help a shitton too. But.....not worth the trouble at this point.
                  • Digitalwave
                    is a poseur
                    • 6299
                    What kind of difference do you notice with no rear bar? Most people go with bigger rear bars, so I wouldn't know what to expect.
                    RISING EDGE
                    • Bavarian3
                      • 1230
                      Tj,
                      Most people go bigger bars due to the lack of spring rates.... though what you 'want' is to have high spring rates with lack of swaybar stiffness... if that makes sense..
                      I'd run a stiffer rate before taking my rear bar out...
                      • rwh11385
                        lance_entities
                        • 18403
                        I notice the rear end not wanting to slide out anymore from under me going around Turn 9 at 75mph, which is a nice change.
                        (was a problem. no rear bar = solution)
                        Big bars in back make e30s twitchy and nervous, according to multiple sources. get-fast (Jon Felton) liked that feeling. I don't. I like stable. I'd probably love an E36, but this helps our e30 trailing arm setups a little bit, as far as I've come across and people I've communicated with about it.
                        http://forums.bimmerforums.com/forum...d.php?t=423480 has a little talk about (running w/o a rear bar)
                        You can eliminate body roll with spring rates and live without a rear bar. I just don't have any need to do so at this moment. Obviously Alex's setup works well too but I dunno how the car is dynamically....but he might need it to be twitchy to dodge all those cones! haha. (what Felton was saying, it may be nervous, but you can point the car exactly where you want it.... only problem is messing up or being a n00b and learning on that)
                        It's nice to not upgrade the rear bar, because you forgo the need of reinforcement and stuff, but can still run M3 front endlinks with the stock or a cabby bar, or go for adjustability with a ST one.
