1989 e30 Touring... this is Betty
  • rzerob
    • Jun 2013
    • 2315
    #211
    I am loving this build. Subscribed.
      • 37828
      #212
      Looking good!
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • pilotskillse30
        • Dec 2006
        • 1957
        #213
        I want to run away and have and affair with Betty
        • MC Hammered
          • Jul 2008
          • 2076
          #214
          I replaced the rear vent gaskets and still noticed a tiny bit of water entering on the passenger side after it rained, this drove me nuts as I knew the new gasket was not seating flush to the opening. It rains a lot in Vancouver so I have to fix this problem, otherwise I'm going to drive around with a pool of water sloshing around in the back.
          Instead of readjusting the gasket and hoping that fixes the problem, I will replace both gaskets with butyl rope. This Proform PF300 is perfect as it comes in nice thin strips.
          Removed the rear bumper to access the vent assemblies, removed both of them and cleaned thoroughly.
          Used some alcohol to wipe down the edges of the opening, followed that up with some water and when dry I applied a couple of butyl strips which will form the new seal.
          Inserted the plastic vent assembly, pushed it into place and the butyl squished around all of the edges making a perfect seal.
          Repeated the process for the driver side and I let everything settle for a couple of days, then I water tested each side for 10 minutes with a hose and no water enters into the cabin!
          My 1989 e30 s52 Touring... this is Betty
          My 1989 325i vert (sold)...this is Nina
          My 1991 M5 (sold)... this is Veronica
          Photo comparison: OEM vs aftermarket windscreen for a convertible
          • GillesBigCowboy
            • 507
            #215
            This is kind of confusing me because in my thoughts of the comic strip, deep down, I always wanted Veronica more than Betty.
            87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
            • MC Hammered
              • Jul 2008
              • 2076
              #216
              I want my garage back :(
              • MC Hammered
                • Jul 2008
                • 2076
                #217
                Water is getting by the tail light gaskets so I ordered a pair and installed them. Today it was raining and when I peek into the jack and battery tray areas there was water pooled up there again!
                I can see where the water trickled in so there has got to be something wrong with both lower sections of the tail light opening preventing the gasket from sealing. What is puzzling is there is no evidence of an accident or damage to the rear of the car, so I can only assume that both tail lights must have been leaking since the car left the assembly line! :(
                If I can't massage the sheet metal to help get a better gasket seal, then the next step is to lay down some strip caulk and see if that keeps the water out.
                • bradnic
                  • Jul 2012
                  • 3550
                  #218
                  amazing to still have leaks back there after all the work.. at least you're on top of things and not letting the water sit there long. good luck chasing it down.
                  HOWTOs:
                  DB vert plastic bumpers
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • MC Hammered
                    • Jul 2008
                    • 2076
                    #219
                    Took advantage of the sunny day we had to go inspect the tail light gaskets and how they are sealing. Looking from the inside of the car the gasket does seem to be forming a very nice seal as I could feel the squashed foam. While examining the tail light I found a tiny pool of water on the trunk floor which could not have leaked in from the tail lights as it too far inward, when I lifted up the piece of foam sound deadening that was touching the pool the water trickled right into the jack cubby floor.
                    I decided to install the new hatch gasket I ordered last year (part 51718134821) as it is the only factory gasket I have not changed.
                    Didn't take any pics of the tedious install, reinstall and 3rd reinstall since my OCD had to get the ends to meet up perfectly. Once the new gasket was in place I closed the hatch and VOILA!! The hatch would not close.
                    Pushed the hatch down hard and it would just bounce off the latch, this proves the old gasket was flattened quite a bit. I adjusted the catch outwards (~2mm) so it would connect with the latch, now I wait for the next rainy day to see if any water gets inside.
                    • DrJosh
                      • 2011
                      #220
                      Did it fix the leak?
                      Do you know anything about wagon pop out rear windows? While searching for more info on them your thread popped up.
                      Anyway, I might be crazy, but I am strongly considering selling the 90 I picked up last year and buying an ix touring while I am over in Europe this summer/fall. I am trying to figure out the logistics of it all.
                      Originally posted by Sonny
                      I am a meme for our community.
                      • Eric
                        • 5139
                        #221
                        Dont believe tourings had pop out windows, mine didn't.
                        • DrJosh
                          • 2011
                          #222
                          Winston I hope you don't mind,
                          I would guess they weren't available stock. But for example,
                          • MC Hammered
                            • Jul 2008
                            • 2076
                            #223
                            The new gasket didn't fix the leak as it is not sealing correctly against the car body on both left and right sides. I will be posting up an update with pics of what I have discovered.
                            AFAIK the touring never came with rear pop out windows and the ones shown in your picture look like the rear windows from a coupe that have been retrofitted in. I do like how they look on that touring.
                            • DrJosh
                              • 2011
                              #224
                              That would be seriously frustrating. You aren't alone though. I have a mystery sometimes happens/most of the times doesn't leak in the trunk of my E30.
                              I like the way they look too. I wonder what the dimensions are of the touring rear window vs the coupes.
                              • leegf
                                • Dec 2010
                                • 1168
                                #225
                                those pop-outs are fantastic!
                                E46t
