More progress on my m10 turbp. Shes Alive!!!
  • terrybpp
    • Sep 2004
    • 340
    Idles great. Need to bleed the brakes so I couldnt take it out.
    Only problem was that oil was spewing out of the turbo. Realized I still had the valve cover breather hooked up to the intake mani. Retarded. So I put a breather on it last night and plugged the throttle body.
    Still need to make a downpipe. Because I ended up using a Borg Warner turbo I have to get a special flange made. So I'm waiting for that to get done.
  • e30325ic
    • Dec 2004
    • 491
    Looking cool curious to see how it all turns out and the power it will produce.
    1990 E30 325ic (sold for more than I paid for it after 5 Years)
    1995 E30 325e (in progress)
    1987 E30 325is (totaled)
    1990 E30 325i
    1991 E30 318is M50 PWR
    1996 E36 328ic
    1997 Z3
    2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)
    • Rob
      • 8166
      looks shitty, but its cheap, I give it a thumbs up!
      BEERTECH
      • 325Projectz
        • Jan 2005
        • 1956
        Haha, I wonder how bad its going to to rip the streets up.
        91 m3
        • asubimmer
          • 6482
          what Em do you have? just the FMU?
          • Digitalwave
            is a poseur
            • 6300
            Looks cool... hope it runs fine. I'll have to see this car in person when its running good. E30 autocross gathering?
            RISING EDGE
            • terrybpp
              • Sep 2004
              • 340
              Yeah, there are a few other guys comming up in january for a Auto X. I figured we could all get together then.
              Shitty....I prefer flat black functional.
              • asubimmer
                • 6482
                • Q5Quint
                  • Jan 2005
                  • 725
                  I think the setup looks good~ the engine just needs a good degreasing.
                  if you look on the firewall behind the intake manifold it looks like there is blue fmu there, but I could be wrong.
                  • asubimmer
                    • 6482
                    ^^yeah thats what it looks like...is that all the em you got terrybpp?
                    • terrybpp
                      • Sep 2004
                      • 340
                      I did the 12:1 FMU, 24 lb injectors, and a walbro 255 fuel pump. Megasquirt is definetly in the future but it seems to be running good now.
                      • Digitalwave
                        is a poseur
                        • 6300
                        How do FMU's work? How do they supply a 12:1 ratio no matter what car its on? Or is it not entirely accurate?
                        RISING EDGE
                        • terrybpp
                          • Sep 2004
                          • 340
                          So far from accurate, thats the problem. Plus they always make the motor run rich due to the extra fuel pressure in the lower boost range. Cartech makes an adjustable FMU but its still vague and double the price. THe FMU is just a starting place to help me learn the ins and outs of the turbo system. Definetly not a final solution for turbo charging.
                          • asubimmer
                            • 6482
                            so why didn't you get the 10:1 fmu?
                            • terrybpp
                              • Sep 2004
                              • 340
                              10:1 would have worked great for the 0-6 boost range but the last thing you want is to not have enough fuel at 10 psi. Always better to run richer than leaner.
