so the lolly pop on the floor? or does the pan hit first?
also, if you got tree-house lolly pops you would be able to go lower till the frame rails hit as they are much smaller.(may have to grind off the lil tabs on the arms as well) all assuming that you raise up the pan so it clears the sub frame.
i REALLY want you to take multiple shots of the geometry on the arms/ tie-rods/ and sway end links.(if they are still attached) please :) i wanna see how everything changes when it airs out.
you have my respect.
edit* if the shots could be done on stock wheels it would be very helpful also. This way people can see a e30 that is only lowered on bottle caps. (although i believe the fenders would sit on the tires) may need a smaller side wall on them
