R.I.Peices, ode to the M42
  • hydrospeed2000
    • May 2005
    • 54
    Well, it happened today, the M42 let loose. Timing chain went and all the nifty little M42 peices followed. So for now the 318is is off the street. For a while, but,,,,,,, lurking in the shadows is new blood. A transplant is foreseen, breathing fire and bringing with it a new found sense of youth, yes folks, the M50 swap is about to start, letters to home and an explaination to my wife will be found somewhere on a stretch of Tennessee twisties when its completed, no forwarding adress and no phone number, all you'll see of me is a big smile and tail lights.....
    This proves the point of the M42 being a work of art, not. It wasn't even impressive, just quit. I would have liked to seen some P.S.E at least! Oh well, scratch me from the purist column, I'm going for speed, I'm going the distance,,,, la, la , laaaaaaaa.
    Anonymity on the internet is courage for the people who have none. You know who you are.
  • asubimmer
    • 6482
    Turbo M42!!!
    • Addissimo
      • Mar 2004
      • 1820
      Awesome.
      i <3 m50
      Doing something M50 related? -> http://www.addissimo.com
      On Myspace? ->http://groups.myspace.com/r3vlimited
      BF2142 SN = BillyGoose
      • redcarbon
        • Apr 2005
        • 213
        dammit, not another one. You're all scaring me. How many miles did it have? I am at 145,000 and on the original chain, I'm pretty sure. I'll change it if I have to, but I've heard it's pretty involved.
        Good luck with the m50.
        318is -gone-
        • ACHTUNG
          • May 2005
          • 2397
          you totally R3Ved
          1989 US E30 Cammed S52
          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
          • DEV0 E30
            • Oct 2004
            • 8904
            Yep needs an oil change now.
            • hydrospeed2000
              • May 2005
              • 54
              I had 158000 on the clock and a warning failed valve spring. Like I said, I knew it was going to happen........
              • Digitalwave
                is a poseur
                • 6299
                That's probably the gayest summary of a dead car that I have read on r3v so far. Do you watch Star Trek?
                Good luck with the motor swap.
                RISING EDGE
                • KangamangusDriver
                  • Aug 2005
                  • 1870
                  One door closes...
                  And a new door opens!!!
                  Good luck with the swap, you will LOVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                  • hydrospeed2000
                    • May 2005
                    • 54
                    It was meant to bait the M42 lovers from behind their respective rocks, or out from their respective closests as your case may be. @ss
                    • ACHTUNG
                      • May 2005
                      • 2397
                      Ha.
                      • Joe318is
                        • Sep 2005
                        • 6451
                        any warnings or did it just go?
                        Originally posted by vlad
                        • hydrospeed2000
                          • May 2005
                          • 54
                          Just went, no warnings, bells or whistles. It left me plenty of time to work up the financial thought process of the M50 swap though.
                          • Joe318is
                            • Sep 2005
                            • 6451
                            Im scurrd!! Workn on 127k, did not replace the timing chain when i had the chance [did the headgasket at 111k]
                            • hamann318is
                              • 3382
                              I don't understand what you guys are afraid about. M20 guys have to replace the belt at 60k, and that's just as detailed as changing the chain on the M42.
                              The system begins to show wear around 100k, and if you're that worried...
                              The BMW 318 is back. With a vengeance.
