Marc and Dudley helped to finish the suspension rehab, which included the front control arms, control arm bushings, tie rods and new power steering low pressure hoses and reservoir for good measure. Here is one of the old control arms.
Now for the control arm bushing. The bushing kit from www.blunttech.com came with a pair of M3 offset control arm bushings for a little negative camber.
Not having a press, I used more primitive installation method.
Then, Dudley and I set about the daunting task of squeezing these bushings onto the control arms. I've heard of people using using a wood block and a sledge hammer to pound these into place, but that method simply did not work for us. Instead, we used a set of spring compressors and a 2002 control arm bolt to force the bushings into submission.
This is only half as dangerous as it looks.
Here we are; ready for installation.
I didn't bother to document the tie rod installation, since it was pretty straightforward. Here is everything in place. Blunt's kit came with new swaybar links as well.
With it all settled in, the ride height is just right and everything feels tight.
I've identified the steering shaft U-joint as the source of the last "clunk" in the suspension and steering, so that will come soon.
Marc also came over and helped to install low pressure power steering hoses and a new reservoir.
