Another 5.0 build: #projectmerica
yes, 87's have transfer pumps. it's in the tank, the high-pressure one is fore of the driver's side rear wheel.
regarding the wiring, the fuel pump relay is an SPST relay. it's hot all the time through terminal 30 and in run/start through 86. it grounds to the DME through terminal 85 when it's in run/start which triggers the relay and sends power to the pumps through terminal 87.
check page 1360-1 http://www.wedophones.com/Manuals/BM...g%20Manual.pdf
since you don't have a DME anymore you could wire it up to complete the ground with the ignition switch. i don't know how to do that, lol.. and i'm not an electrical kinda guy so read all this with a grain of salt (or two)Comment
I figured out the issue with the fuel pressure. Turns out the stock return line is too small if I want to run the stock fuel pumps. It can't handle all the fuel that that FPR is sending back. I'm just gonna rerun the fuel lines and prob run a lower psi pump.Current Moneypits: e36 m3/4/5 Turbo Techno
1961 Cadillac deVille bagged - IG @bryang513
How's the build coming?sigpic
Instagram @rebellionforgeComment
haven't had time to work on it recently. I need to figure out how i want to do the fuel delivery. Stay with the stock pump or not? If I stay I need to run a larger return line back and that may be a bitchCurrent Moneypits: e36 m3/4/5 Turbo Techno
I can't remember, does that drop back into the top of the tank? I sold mine 2 months ago so I can't remember. Dropping it wasn;t to bad. Look at it this way, if you go crazier with the motor down the road your return setup will be ready hahaha.sigpic
I bet it you loosened the bolts on the tank and dropped it about an inch you could do it. That's how I initially unhooked the wiring before I decided to drop it.sigpic
I used the stock location of the main pump. stock lines, wiring, everything with the holley blue. You'll wanna keep the lift pump unless your doing a fuel cell as the holley (or any inline pump) is a push type and you'll create a cavity in the line and burn up the pump if you dont have it within 1ft of the pickup and dont have the lift pump.Comment
ok I was thinking about doing this? How exactly did you wire it up? Is it on a switch? Do you still have your ECM in? Relay?I used the stock location of the main pump. stock lines, wiring, everything with the holley blue. You'll wanna keep the lift pump unless your doing a fuel cell as the holley (or any inline pump) is a push type and you'll create a cavity in the line and burn up the pump if you dont have it within 1ft of the pickup and dont have the lift pump.Current Moneypits: e36 m3/4/5 Turbo Techno
Ok so it turns out that I only have one in-tank pump? Unless it's on top of the tank where you can't see it.
I ended up running a new larger return line, but it didn't completely resolve my high pressure issue. I tested it some more and the bottleneck is now occurring at the nipple going into the tank. I was about to just put in my aftermarket pump, but my buddy mentioned using a resistor to knock down on the pressure that the stock pump delivers. Good thought? It worked.
Any issues foreseen with doing that?Current Moneypits: e36 m3/4/5 Turbo Techno
Video of a burnout or it didn't work.......sigpic
FAR to few updates on this build.....Seriously get on it already hahahasigpic
