Another 5.0 build: #projectmerica
  • TYBG
    • May 2012
    • 143
    #271
    i been wanting to do a 5.0 swap and the pictures just make it look more and more appealing
    • evandael
      • Oct 2009
      • 2881
      #272
      taking a stab at this because i'm not familiar with carbs, but..
      the late model stock pump may run too much pressure for a carb. investigate using the low pressure transfer pump from early model e30's.
      also the fuel pump relay wire for e30's is c101 pin 13. it's a green/violet wire. double check the ETM's for your particular model/year here
      • eurotrash
        • May 2007
        • 768
        #273
        Have to run an adj fpr. The holly regs are crap. Also do you have the return line hooked up? I run a mallory 4309 with a holly blue pump and the return line hooked up. You want 6-7 psi for a holly based carb.
        • ballski
          • Jun 2012
          • 345
          #274
          I have that wire running to the positive from the battery on a switch. But it's always on then. I was looking for it to only be on with the ign switch. It's an 87 so I'm not sure if it has a secondary pump? Ha
          Yes I have the return line hooked up and the adj FPR. Do you have the pump on a switch or relay?
          Current Moneypits: e36 m3/4/5 Turbo Techno
          1961 Cadillac deVille bagged -
          IG @bryang513
          • eurotrash
            • May 2007
            • 768
            #275
            Pump is all the stock wiring. Seems to be sufficant enough. Id say its less about your pump and more you fpr just not being able to go that low. Theres a dif between high pressure and low pressure fpr. Buddy is running the same mallory fpr as me with a walbro 255 on his sbc swapped 240 with a 750double with zero issues. Prob just gotta get a low pressure fpr. Mine is listed at $99 on summit right now and has 4 ports plus a return and you can run it with boost via the vacume port.
            • ballski
              • Jun 2012
              • 345
              #276
              Mine is a low pressure FPR: http://www.summitracing.com/parts/HLY-12-841
              IG @bryang513
              • eurotrash
                • May 2007
                • 768
                #277
                Idk make sure the return line is coming from the proper port?
                • ballski
                  • Jun 2012
                  • 345
                  #278
                  yes did that. It's labeled on the FPR also
                  IG @bryang513
                  • eurotrash
                    • May 2007
                    • 768
                    #279
                    Could it just be your gauge is bad?
                    • ballski
                      • Jun 2012
                      • 345
                      #280
                      that was my only thought also. It's brand new, but a cheapish one
                      IG @bryang513
                      • eurotrash
                        • May 2007
                        • 768
                        #281
                        Are u black? Is it black? Maybe its racist?
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #282
                          Did you ever get your Kamotor flares mounted?? I'm seriously thinking about selling my DTM's and getting his extra wides..........
                          Instagram @rebellionforge
                          • ballski
                            • Jun 2012
                            • 345
                            #283
                            No but it's very possible lol
                            Not yet, I've been slacking. I have been concentrating on getting the car running and driving next
                            IG @bryang513
                            • IronFreak
                              • Dec 2012
                              • 3702
                              #284
                              Did you get his extra wide flares?
                              • shEck3lls0
                                • Jan 2011
                                • 1154
                                #285
                                I'm interested in how the exhaust comes along. I just bought a set of BBK shorties off ebay for real cheap. Also have Stuart's long tube cobra headers I might experiment with. Trying to help Stuart engineer an exhaust for his car. We all know he wants one. ;)
                                1989 Alpine 325is 2dr m50 swapped
                                Build Thread:
                                Current ongoing build. Check it out!
                                1991 318is 4dr rallycross
                                Rallycross Build Thread.
                                1991 Alpine 318is coupe - sold
