My 1985 325e [Picture Heavy]
  • Wardie
    • Oct 2012
    • 824
    #121
    No idea. Ecu?
    Schwarz 1985 325e
    • DER E30
      • Sep 2013
      • 2349
      #122
      http://www.e30zone.net/e30zonewiki/index.php/Ignition Helpful??
      -Christian
      • DER E30
        • Sep 2013
        • 2349
        #123
        Do you have a multi meter?
        -Christian
        • DER E30
          • Sep 2013
          • 2349
          #124
          Is the ignition controlled by MS2 at all? OR is it ALL mechanical?
          -Christian
          • Wardie
            • Oct 2012
            • 824
            #125
            I have a multimeter, with car in the on position and I do power to power and ground to ground I get a blip of power then reads 0. If I do power to strut tower ground I get 11v-12v. Leads me to believe something with the ground. The ground goes straight into the ecu.
            Schwarz 1985 325e
            • Wardie
              • Oct 2012
              • 824
              #126
              Maybe my OBC?
              Schwarz 1985 325e
              • DER E30
                • Sep 2013
                • 2349
                #127
                Originally posted by Wardie
                That's really interesting... I just googled "e30 obc relay" and came up with some other instances of this making the car not run...
                -Christian
                • Wardie
                  • Oct 2012
                  • 824
                  #128
                  Yeah I was having problems with it before the car was done. I will check it tomorrow after work. I'm frozen and tired haha.
                  Schwarz 1985 325e
                  • DER E30
                    • Sep 2013
                    • 2349
                    #129
                    Can you just bypass it with jumperwire??
                    -Christian
                    • e30austin
                      • 15382
                      #130
                      Unplug the obc and the obc control box that mounts to the firewall. Look at your fuse able link and crank sensor as well. Make sure you didn't wire your harness backwards. Your shock tower shouldn't have any power...
                      • Wardie
                        • Oct 2012
                        • 824
                        #131
                        If I unplug it would it still work? Crank sensors brand new, not sure how I'd wire it backwards. Shock tower doesn't have power but when I use it as a ground it shows the coil getting power but if I check the two poles on the coil I don't get any read.
                        Schwarz 1985 325e
                        • e30austin
                          • 15382
                          #132
                          The OBC won't work when unplugged, but all you want to do is test to see if that is your issue or not. If it isn't, then plug it back in.
                          • Wardie
                            • Oct 2012
                            • 824
                            #133
                            Well obc turns on and all that jazz. I know if it's unplugged it won't work. If it's unplugged though does that by pass something and allow the coil to get power?
                            Schwarz 1985 325e
                            • e30austin
                              • 15382
                              #134
                              The "anti theft" system on the OBC sometimes gets super fucky and will cause things such as this.
                              • Wardie
                                • Oct 2012
                                • 824
                                #135
                                Alright I'll try after work and let you know what happens. Thanks.
                                Schwarz 1985 325e
