Originally posted by kronus
View Post
agent's 24v build thread
Originally posted by agent View PostYou're right - they just go to the rear wheel wells. I'll be taking some more pics when the harnesses, the seats and their mounts arrive, hopefully this week.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"
I made a little progress over the weekend, though it wasn't nearly as much as I'd hoped since I was sent two different styles of floor mount adapters. Note the disparity between the number of bolt holes on the outer brackets in the first and second pictures:
Needless to say, I was pretty miffed when I made this discovery yesterday while trying to figure out why the passenger seat simply would not bolt in; I used the driver side outer as the template for lining up the side mounts. Once the correct passenger outer bracket arrives I'll be able to do final fitting and placement on the seats, then drill holes to mount the eye bolts and backing plates for the six point harnesses.
Originally posted by Ether-D View PostI would say that the rear wheel wells certainly resemble structural sheet metal.
in a rollover or a major rear collision the rear stays will punch through the wheel wells without much hesitation.
an example of structural sheet metal is something with a box section, like the frame rails that hold the rear upper spring perches and rear bumper shocks.
an example of structural sheet metal is something with a box section, like the frame rails that hold the rear upper spring perches and rear bumper shocks.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"
They resemble pool noodles...
Couldn't resist. I'm truly sorry.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"
