agent's 24v build thread
  • agent
    Vice Grand Pubaa
    • 7960
    #121
    Originally posted by kronus
    not sure that those rear stays are going to anything resembling structural sheet metal. I know it's a prebuilt cage and all, but all the serious cages I've seen (quite a few) go down to the rear frame rails.
    what do your main hoop and front downtube spreader plates look like?
    You're right - they just go to the rear wheel wells. I'll be taking some more pics when the harnesses, the seats and their mounts arrive, hopefully this week.
    • Ether-D
      • Sep 2011
      • 2838
      #122
      I would say that the rear wheel wells certainly resemble structural sheet metal.
      Originally posted by Andy.B
      I was born on 3/25…
      • agent
        Vice Grand Pubaa
        • 7960
        #123
        I made a little progress over the weekend, though it wasn't nearly as much as I'd hoped since I was sent two different styles of floor mount adapters. Note the disparity between the number of bolt holes on the outer brackets in the first and second pictures:
        Needless to say, I was pretty miffed when I made this discovery yesterday while trying to figure out why the passenger seat simply would not bolt in; I used the driver side outer as the template for lining up the side mounts. Once the correct passenger outer bracket arrives I'll be able to do final fitting and placement on the seats, then drill holes to mount the eye bolts and backing plates for the six point harnesses.
        • kronus
          • Apr 2008
          • 13032
          #124
          you'd be wrong..
          in a rollover or a major rear collision the rear stays will punch through the wheel wells without much hesitation.
          an example of structural sheet metal is something with a box section, like the frame rails that hold the rear upper spring perches and rear bumper shocks.
          cars beep boop
          • agent
            Vice Grand Pubaa
            • 7960
            #125
            Finished up the install of the quick release, pedals, seats, harnesses and roll bar padding today.
            • Ether-D
              • Sep 2011
              • 2838
              #126
              you'd be wrong..
              I get it bro. I was being hilarious using your wording about it not "resembling" structural metal.
              I was born on 3/25…
              • kronus
                • Apr 2008
                • 13032
                #127
                :up:
                seat install looks good. pool noodles?
                cars beep boop
                • agent
                  Vice Grand Pubaa
                  • 7960
                  #128
                  Thanks, and negative. It's offset roll bar padding, similar to this:
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #129
                    They resemble pool noodles...
                    Couldn't resist. I'm truly sorry.
                    I was born on 3/25…
                    • kronus
                      • Apr 2008
                      • 13032
                      #130
                      neat! didn't know they made it offset.
                      cars beep boop
                      • warshark
                        • Nov 2015
                        • 52
                        #131
                        that was a quick build how does she run
                        • 2mAn
                          Señior Mod
                          • 21017
                          #132
                          Where did you get the offset pool noodles?
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            #133
                            Sorry Simon, just saw this. I got them from Summit Racing.
