How many of you guys are rocking BBS RC 090's?
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback Thread -
Here are some old pics I dug up. As any fitment issues with this car are long gone now.
Most of these are on 5mm spacers and a proper working of my eastwood roller. Far from a stance car. I could've put 235s all around no problem. These were my street wheels, my track setup was 245/40 R888s.
When I was searching to see if these would fit I saw posts all over saying NO WAY MAN! but I did it anyways. It works. Please don't spread misinformation.
2003.5 Imolarot M3: daily
1995 Alpinweiß M3: hpde
Lol, look how much negative camber you're running in the front, and how pulled out your front fenders are. You're missing the point. Yes, you got them to work with your particular setup. Not everyone wants to run 4 degrees of negative camber and pull their fenders out like that. It may be proper to you.. it's a track car. But it's not proper for a car driving 80 miles a day with softer suspension and someone not wanting their fenders to look like that.Here are some old pics I dug up. As any fitment issues with this car are long gone now.
You do acknowledge that e36 suspension pokes out at least a measurable amount further then stock e30 suspension, correct? OK, now, if I am hitting my tires on my fenders with stock 4 lug with 17x8 et20 with 215/40/17's, then it can only be a fact that I will hit them even more by spacing the same size wheel/tire out more with the e36 suspension, correct?
That is the point.Comment
I understand that. Now you typed a valid explanation. Before you just vaguely said that you need e30M stuff. That's not true. What if someone who was building a car on coilovers and running a stiff setup came and read that. They would second guess their build. Nothing against you, I'm just saying don't post something just to post it.Lol, look how much negative camber you're running in the front, and how pulled out your front fenders are. You're missing the point. Yes, you got them to work with your particular setup. Not everyone wants to run 4 degrees of negative camber and pull their fenders out like that. It may be proper to you.. it's a track car. But it's not proper for a car driving 80 miles a day with softer suspension and someone not wanting their fenders to look like that.
That is the point.
FWIW, I did drive the car like that around 70 miles a day, it was 3.2 degrees up front and 2.1 in the rear and my fenders look like that because they were 90% bondo lol.
For anyone curious to how much poke there is, here is a pic from my build thread. Cut off flares in the rear. 318Ti 5 lug. 8"et20 215/40-17
Furthermore, according to my calculations, if the e36 318ti stuff does indeed stick out 23mm more then e30 rears, then the same 235/40/17 that I have on my 4 lug (with 17x9 et25 with 8mm spacers) would stick out 7mm further when used on a 17x8 et20 with the 318ti stuff. Currently, my car rubs the outer wheel well (not the actual 1/4 panel, but the wheel well itself, which can't be rolled or pulled) under full throttle. I tried 10mm spacers, the tire basically rubbed over every imperfection in the road. Using 318ti in the rear would basically make it the equivalent of using 15mm spacers on my current setup. The tire would probably be against the wheel well when the car was sitting still. AKA, doesn't work.Comment
No I didn't. I think you're confusing me with someone else.
What you posted was just as bad. Go look at the 5 lug forum. It's full of people pissed off that they did 5 lug swaps because they read that they'd have great wheel selection by going 5 lug. Now they're realizing they are stuck with high offset wheels because they don't want to run crazy camber and make their fenders look like yours (no offense, but it looks horrible, thy look like someone grabbed them and just pulled as hard as they could). That's the ONLY reason you're able to run those wheels/tires.
The truth is, e36 m3/318ti 5 lug adds at least 15-20mm of poke to your wheels. That's all there is to it. People can take it for what it is and decide for themselves what they can get to work that fits their needs. But it is a fact that a 17x8 et20 with 215/40/17's will not clear the fenders on a lowered car unless they run significant front camber, limit suspension travel, and/or pull the fenders. So he wasn't wrong.Comment
I have e36 5 lug. My rc090s fit before any rolling of fenders. That's my story.
Have a good weekend.
Lol, with over 3 degrees of camber!
OK everyone, you can all go bolt 17x8 et20 wheels on your e36 5 lug e30's. Even though there is a whole thread with people posting their fitment issues with that exact setup, those people are wrong. They must be doing something wrong. Every e30 should have 3+ degrees of camber and stiff springs. Anything else is incorrect.Comment
^^Thissigpic
Poorboyz Feedback ThreadComment
Alright guys, I really appreciate all the info, lets get back to some pics? Also, nobody answered if you could use flat caps on these style 5's. I haven't seen anyone run them, and think they would look good. Also, I am running a 4 lug setup, I have an early model(as can be seen in my images) and want to run adaptec adapters, probably 18 to 20mm. Probably run 225 or 235/40 in the back and 215/40 up front. I know I will have to do some fender rolling, thats fine. Do you think I will have to do any pulling on it? Here are some pics of the wheels propped up on my snowboarding boots, don't hate ha.
86' silver arctic metallic es
My rears are essentially 8" et-3 in 4 lug terms. Basically what you would be at with those adapters. I'd recommend a 215/40 all around to make it easier. You will have to pull them pretty good if your suspension isn't super stiff.Alright guys, I really appreciate all the info, lets get back to some pics? Also, nobody answered if you could use flat caps on these style 5's. I haven't seen anyone run them, and think they would look good. Also, I am running a 4 lug setup, I have an early model(as can be seen in my images) and want to run adaptec adapters, probably 18 to 20mm. Probably run 225 or 235/40 in the back and 215/40 up front. I know I will have to do some fender rolling, thats fine. Do you think I will have to do any pulling on it? Here are some pics of the wheels propped up on my snowboarding boots, don't hate ha.
http://imgur.com/a/ISygA
