2nd e30, 87 Lachssilber Revival
  • 2mAn
    Señior Mod
    • 21005
    #376
    No rust hiding under all that?
    When are you buying a welder to start the never-ending rust repair?
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • Reichart12
      • Aug 2012
      • 2165
      #377
      No rust there, only discolored adhesive. The rust in the trunk is bad but only in the side cubby areas. MIG welder acquired. Waiting to pick up a gas tank. The store was out last week when I stopped by. Not sure yet what I will attempt to tackle first. Definitely spending a few weeks just practicing on scrap metal as I've never welded before haha.
      Instagram: Reichart12
      • 2mAn
        Señior Mod
        • 21005
        #378
        Just dive right in! lol
        I went back and watched my episodes of the rust repair on the Alfa... woooo boy, I do not miss those surprises I found. Granted yours shouldnt be as bad, but still.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        • Northern
          I like cupcakes & sh!tboxes
          • 5283
          #379
          What are you planning for gas? IMO my biggest fuck up with my MIG setup is renting a tank instead of buying one. It's been like 10 years, 2 exhausts, a FSAE car, a bunch of subframes/misc shit/bodywork and I still have never refilled the full size tank that costs me like $200/year... No idea what the tank costs these days though, or if you can buy a second-hand one and have it filled.
          On the other hand, the TIG tank was toast after a year of little shit and one aluminum gangway.
          Aside from using shielding gas, dropping down to 0.025" wire made a massive difference for me. Then cleaning metal properly, some nozzle gel to help spatter not stick to the tip, and the rest is just practice.
          Originally posted by priapism
          Originally posted by shameson
          • Reichart12
            • Aug 2012
            • 2165
            #380
            Finally install a stud conversion that I picked up a year or two ago. Not much to say about the process. I enjoyed the time hanging out in the garage. Not sure what's coming next, tempted to make a carbon fiber plate filler. Almost to year 11 of ownership!
            • Northern
              • 5283
              #381
              love a stud conversion. makes such a difference when changing wheels, and looks good too.
              • Reichart12
                • Aug 2012
                • 2165
                #382
                The real motivation is that all my set screws were stripped so sometimes the rotor would wiggle and overlap the lug bolt holes making it tricky to thread in. No more issues with that now haha.
                • Reichart12
                  • Aug 2012
                  • 2165
                  #383
                  I'm doing it. I'm jumping into rust repair. Starting with the rear to fill some holes leftover from the US bumpers and going from there. I'll have an order to Valcas Garage shortly to get patch panels. Am I in over my head? For sure. Do I care? No. I can't mess the car up any more than it already is. I will keep frequent updates as I'm sure I'll need the support and know-how as I work my way through.
                  Tore the car partly down to check out what damage I'm working with.
                  • e30m3s54turbo
                    • Jun 2010
                    • 3291
                    #384
                    On one of e30’s had rust on rear end on battery hole on the bottom. I was going to cut it out and repair it myself. I did cut the rear out of a red e30 vert in the wrecking yard. I had a shop repair it for me while my exhaust was being worked on it.
                    I look forward for your rust repair fix.
                    • Northern
                      • 5283
                      #385
                      Wish I had more of this vibe going on. IMO it's the right call. Valcas stuff should be easy for like trunk pockets, hopefully puts you in a position where there's minimal fuckery to sort out.
                      • 2mAn
                        Señior Mod
                        • 21005
                        #386
                        Watched the video last night. Definitely patch the trim holes first (thats the ~10-12 along the top ridge). That will be relatively easy and good practice to get your welder setup. From there just slowly work your way down to the larger patches. Some new tools are about to be purchased! So Exciting!!...
                        The battery box will be a real chore, so you want to build up your skills to that point.
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • Reichart12
                          • Aug 2012
                          • 2165
                          #387
                          Thanks! Should be cutting metal out soon.​
                          Yeah, the cost of their pieces vs flat metal panels made sense to me. The ease of a first timer should be helped with this.​
                          More tools! More tools! More tools!
                          • Reichart12
                            • Aug 2012
                            • 2165
                            #388
                            First time welder cuts up his e30.
                            Overall impression of the first attempt at rust repair, I think it went well. It's not a great job but even doing this small area I think I learned a bit on how to do it better next time. Probably ~6 hours in on this spot in a weekend.
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              #389
                              A functional repair. If you want to replicate the textured paint finish I've had good luck with primer, then random paint, then undercoating that you artfully dab with a microfiber or other cloth while wet to simulate the texture.
                              • Reichart12
                                • Aug 2012
                                • 2165
                                #390
                                Smart, I had not put much thought into making the texture yet. Not sure of what my plan will be post-rust repair but some level of paint/wrap will be needed.
