Finally done. Shaved bay, wire, brake line, and radiator tuck.
  • jhaurimn
    • Nov 2012
    • 2224
    #31
    Looks awesome!
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • Habla
      • May 2004
      • 1470
      #32
      Ok I need to know what those wheels are! Prease?
      -Peter
      318is slicktop | F15 35dM | F250 SD
      • Zreberlcoe
        • 1555
        #33
        Well fuck me right? Gorgeous car man!
        1991 325i Calypso Coupe
        Like Grandfather, Like Father, Like Son
        BMW
        • Divbetic
          • Feb 2014
          • 43
          #34
          Absolutely gorgeous bay you have there, Stunning job!
          • Lgfrommv
            • Aug 2012
            • 16
            #35
            Holy clean!!
            • meanEG
              • Oct 2013
              • 562
              #36
              how do you fill and bleed the cooling system? if this going to be a daily? thats a smaller radiator than any car i have seen on an engine that is known to have cooling system issues. please tell me more
              Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
              • Jack89i
                • Dec 2013
                • 240
                #37
                wow.. that bay makes mine look like shit. Cleanest I've ever seen.
                How does one tuck a radiator and brake lines? where are the coolant hoses?
                sigpic'89 325i
                M60 swap in progress
                • NickL
                  • 562
                  #38
                  Coolant hoses are in the exact same spot, used oem e34 hoses. The system was bled using a vacuum bleeder, it's the only way to completely evacuate the system of air, because as you see the rad sits lower and is no longer the highest point in the system. It cools better than the previous m42 radiator. Can let it sit and idle all day, fan is wired via oem wiring and the temp switch was relocated to the backside of the rad and functions like stock. No additonal switch, etc.
                  Brake line tuck started with a massive booster delete, and e21 master. Abs was deleted, lines run down and one out to the driver, one across the small lip on the subframe to the passenger. Can't see them whatsoever besides the 5 inches off the master down to the subframe.
                  Harness was trimmed, sent through the drivers fender and around front of the car.
                  Wheels are ccw classic 5's.
                  Thanks for the comments everyone.
                  1987 325is - S52
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #39
                    I admire you for even having the patience to even do that..
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • bruner
                      • Aug 2013
                      • 402
                      #40
                      This is hands down the cleanest and best tucked e30 bay I've seen. I've always loved your car, but this takes it to a whole new level
                      90 M3 brilliantrot/schwarz
                      90 M5 brilliantrot/schwarz
                      87 325 alpinweiss/houndstooth (building)
                      90 735i/5 islandgrün-metallic/schwarz (daily)
                      87 Foxbody Notch 5.0 5spd SSP (other daily)
                      71 F-250 4x4 390 4spd
                      • Graebmw95
                        • Mar 2014
                        • 362
                        #41
                        How many horses?! :D seriously beautiful though. Major props.
                        • SteadyAim.
                          • Jan 2013
                          • 249
                          #42
                          Looks great!
                          '90 Alpine White M3
                          OEM Hella Smoked Euro Smileys | OEM Headlamp Washers | Startec Tail Lights |
                          EVO III Undertray | EVO III Front Lip | '92 DTM CF Gurney Flap | Recaro N'Joys |
                          Ground Control Coilovers | OZ Futuras
                          DD: '97 Alpine White M3/4/5
                          • bmwandhonda
                            • 646
                            #43
                            Your car is amazing. Great work with the engine bay by the way. One of the best I have ever seen as a complete package :)
                            Next step is tucking that fuse box and firewall loom.
                            E30 325i Touring currently under construction.
                            http://www.r3vlimited.com/board/show...256444&page=20
                            • Joe G
                              • 2942
                              #44
                              fuck you.
                              Current Car: 2011 BMW 135i, M-Sport, 6 speed
                              Originally posted by lambo
                              Sounds like you need a massage.
                              Originally posted by kpeng
                              Who the hell is Vlad?
                              • meanEG
                                • Oct 2013
                                • 562
                                #45
                                the cars looks nice, BTW.
                                so no need on the expansion tank because you are using a conventional cap now, so all you have is a overflow tank? that's cool. I just got done doing my bay. I did the same thing with the brake lines. I didn't go through all the hole filling that you did. I just did the brackets. I did hide the harness and fuse block though. again it looks nice.
