Finally done. Shaved bay, wire, brake line, and radiator tuck.
  • Jb325is
    • 2137
    #46
    Really nicely done. You bringing this to Sowo?
    How's the pedal pressure with the booster delete and stock brakes?
    - '88 m54 coupe
    <3
    • pilotskillse30
      • Dec 2006
      • 1957
      #47
      What a bay!
      • NickL
        • 562
        #48
        Yeah it'll be at Sowo, the pedal is a bit stiffer but its not bad. Braking power did suffer though with the stock calipers, they're definitely the weak point. I have Hawk pads and nice rotors, but I plan to do an RX-7 upgrade and plumb a bias valve in as well soon.
        1987 325is - S52
        • jd_e30
          • Mar 2014
          • 171
          #49
          Nice work!. I know how much work wire tucking can be... raw fingers... lots of swearing. Takes a LOT of work but is well worth it. Love the stance of your car too!
          1990 325i
          • glnr13
            • 1334
            #50
            really, really nice work! inspiring for sure.
            • RUFFLZ
              • Apr 2011
              • 3122
              #51
              I luhh when my bae is freshly shaved
              • LJ851
                • 7919
                #52
                Looks really good.
                I think your header wrap takes away a little of the super clean vibe you have going on. It always looks a little scraggly and doesn't age very nicely. Have you considered ceramic coating your header for similar function but a look that matches the sleekness of the rest of the bay ? There are a lot of color choices available.
                Also, if you could lose the fuse box...
                Lorin
                The M30 is God's engine.
                • NickL
                  • 562
                  #53
                  Originally posted by LJ851
                  Looks really good.
                  The header wrap is strictly to cover the shitty looking race lands, after a season of driving with them they looked terrible. And yeah, tucking the fuse box would have been nice, but I didn't want to deal with it, nor did I really want it done anyways. I like the oem feel it still gives the bay. Thanks man
                  1987 325is - S52
                  • Stitche30
                    • Jun 2012
                    • 64
                    #54
                    someone needs to do a write up on wire tucking
                    • Jib05
                      • Aug 2012
                      • 149
                      #55
                      Damn. LIKE.
                      .................................................. ...................sigpic
                      .................................................. ............................. ......M50B25 3.1L stroker
                      • CubbyChowder
                        • Mar 2012
                        • 1488
                        #56
                        beaut
                        --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
                        --Golden Boy E30 Build Thread-- (sold)
                        • Peterkaczynski
                          • Nov 2008
                          • 2587
                          #57
                          whoa
                          e24 e9 e30
                          IG: peterkaczynski
                          • bmwandhonda
                            • 646
                            #58
                            Pretty much no easy way of doing it with the e30. All the wires are complete from the fuse box to each accessory/sensor with no connection blocks etc So pretty much all cables going into the bay as well as going to the front end need to be cut and extended.
                            At least that's how i found it.
                            NickL did an awesome job by the looks of it though, one of the cleanest out there!!
                            E30 325i Touring currently under construction.
                            http://www.r3vlimited.com/board/show...256444&page=20
                            • wazzu70
                              • Jan 2005
                              • 1143
                              #59
                              Can you get a picture of the shock tower? The black makes it hard to see. The upper piece and lower piece dont fit together so smoothly. How did you handle that?
                              Thanks!!
                              -Nick
                              M42 on VEMS
                              • m3j0n
                                • Feb 2006
                                • 395
                                #60
                                fantastic!!! make me want to paint my e30 jet black and shave the bay! where is the coolant tank?
