I did end up needing to twist the shift rod ever so slightly to get the shifter to be perfectly centered. Probably about 3 degrees of twist. T'was easy though, vise and a pipe wrench.
M30b34 E30 twin-screw supercharged muscle car
Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?" -
Mmmk, so I tried to stick the head on to check clearances. Turns out I needed to smack my firewall some more. So I slapped that bitch around some and set my head on with 1mm of space between the head and firewall. Then sorta temporary-like added the old school manifold. There may be some clearance related riggery needed. The hood will be getting a "vent" of some degree later on for the "shotgun intake scoop". I haven't tried it with the original intake manifold. I bet it's a little lower profile.
Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Lookin good! You got the right clearance on the distributor cap to the radiatorComment
Thanks man.
An idea crossed my mind this morning a few days after someone mentioned carbs. Triple deuces. That's old school muscle style. Idk, nothing is set in stone...Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Oh wow. Carbs are rather expensive ($1300-$1600 for three). MS2 is waaaaaay cheaper. Carbs schmarbs...Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Theres lots of options for fueling these motors. I was going to run twin weber 32/36s using an old Bavaria intake manifold but decided to go megasquirt instead. Theres even a marine intake manifold that bolts up and would allow you to run a good ole holley 4b
Bavaria manifold
personally I think a cammed out, carbed, euro bumpered m30 e30 would be badass shitLast edited by totheredline; 10-05-2014, 08:45 AM.= Heidi 1988 325 -> 335i. 7200rpm built M30Comment
Whoa. Those are pretty badass. Good infos.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
You don't have to go marine to get the 4 barrel manifold, early 7 series had them. I have 1 of each setup of course , single 4 barrel, twin 2 barrel, triple sidedraft. All the carb manifolds are made for small intake ports like your early intake manifold.Comment
Of course.:eeek:
I'm probably gonna just end up using the first section of the old manifold to bolt my supercharger box to, just like my m20 version. I'm kinda holding out for a different version, but it does work well.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Alright, motor back on the stand and I'm gonna get after the re-gasketry of it. then set her in for good. That went kinda fast in my world. Now I need to make a damn decision about whats gonna manage this motor.
Motronic 1.1?
pros: free (cause it came with the motor)
cons: rough idle, old tech, blah blah, won't do boost
1.3?
Pros: better idle, newer tech, slightly prettier
cons: not free, gotta rig up crank sensor, buy harmonic balancer, won't do boost
MS2?
pros: ummm everything
cons: $700, harmonic balancer, $$$, $$$
ADHD moment, did yous guys know that auto zone.com has all of the torque specs for the important bolts?Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
m30b34:
Rod bearing cap nut torque: 40ft/lbs
Main bearing cap bolt torque: 44ft/lbs
Head bolt torque: 58-59ft/lbs
Intake nut torque: 23ft/lbs then 32ft/lbsOriginally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
I'd go 1.3 it's what I'm running and it makes it easier to wire to the car imoComment
It is, Right now it's just about the harmonic balancer from the b35. I need to just put an ad in parts wanted… Then I'd just put an m20b25 harness on it and the ms2 would be a breeze.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
Bottom end disassembled and reassembled to proper torque specs with assembly lube. Timing cover gasket and front seal replaced. Rear seal and housing gasket replaced. Smaller oil pump gear and shorter chain installed. Oil pump, pan, and gasket installed.
Head is next. Anybody know how to time these motors? There is no obvious mark on the cam gear. The crank tdc is clear.Originally posted by Andy.BWhenever I am about to make a particularly questionable decision regarding a worryingly cheap diy solution, I just ask myself, "What would Ether-D do?"Comment
