M30b34 E30 twin-screw supercharged muscle car
  • Ether-D
    • Sep 2011
    • 2838
    #121
    Measured the space between the g240 output flange and the diff flange, got 59". Measured stock m20 g260 driveshaft (mostly compressed), got 58 1/2" (including guibo). Yeah, that'll do just fine...
    Originally posted by Andy.B
    I was born on 3/25…
    • Andy.B
      • Sep 2011
      • 1650
      #122
      Glad it's working out! Did you get mounts welded up yet?
      • Ether-D
        • Sep 2011
        • 2838
        #123
        No man, I've got the motor in the bay, but my tools for steel working are a bit limited. I probably won't get anything done until next week. I'm working like a dog all this week. It's fall break next week and my kids will be with me so I'll be able to be home and do some work on it.
        I was born on 3/25…
        • Ether-D
          • Sep 2011
          • 2838
          #124
          M30b30 manifolds are neat...
          So I'm at the pullpart yesterday cause they had this old 1977 530i. I had seen pics of the intakes on older m30 motors and they kinda talked to me. They are made up of 9 separate pieces. 6 U-shaped runners that connect the "log" to the 2 actual intake flanges. The possibilities are endless. Think, what could be mounted to these U-shaped pieces. Hint: It's a supercharger manifold. Oh crap that wasn't really a hint...
          I was born on 3/25…
          • Andy.B
            • Sep 2011
            • 1650
            #125
            That's a cool find! I kind of hate the look of the typical m30 intake, but that setup looks great. How does the port size compare to the b34?
            • slammin.e28
              שמע ישראל
              • 12054
              #126
              Get the "logs" off of an e21. They are an upgrade.
              • Ether-D
                • Sep 2011
                • 2838
                #127
                I'll let the pics do the talking. Then I'll talk.
                Yeah, so a little smaller, but I think a die grinder could do wonders. The inside diameter of the runners (u-shaped) is 1 3/4". The dimensions of the runner at the head 1 5/8"x1 1/4" so significantly smaller for to speed up the air. I'll likely just grind off the bump and go with it.
                I was born on 3/25…
                • LJ851
                  • 7919
                  #128
                  What kind of manifold is the one on the left? It does not look like a B34 port shape.
                  Lorin
                  The M30 is God's engine.
                  • 2mAn
                    Señior Mod
                    • 21024
                    #129
                    You could also go with ITBs or Carbs... Very cool indeed :up:
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • LJ851
                      • 7919
                      #130
                      I think the injector orifices in the earlier manifold are not compatible with electronic fuel injectors, some adaptation may be required...
                      You should have someone airbrush to banana tubes to look like actual bananas.
                      Lorin
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #131
                        The manifold on the left is the one that came on my free m30b34. It says 3.2/3.5 on it. I thought that was the tell. If it said 3.5 it was a b35, if it said 3.2/3.5 it's a b34. But it certainly could've been modified at some point I reckon.
                        And LJ, correct about the injector orifices. They're not quite deep enough, but a little augmentation will have them juuuuust right.
                        I was born on 3/25…
                        • LJ851
                          • 7919
                          #132
                          All B34 intakes/heads basically look like the older manifold in your pictures. B34 manifolds also have 2 steel braces from the top of the manifold to the valve cover where as the B35 does not.
                          Post a pic of the intake ports on the head.
                          Lorin
                          • Ether-D
                            • Sep 2011
                            • 2838
                            #133
                            Here ya go.
                            [/url]
                            I was born on 3/25…
                            • chondamx
                              • 247
                              #134
                              Because: awesome.
                              '91 318is M52 Turbo (in pieces)
                              • LJ851
                                • 7919
                                #135
                                Here ya go.
                                [/url]
                                Hmmmmmm...Casting date on the head and does it have "M90" cast into it anywhere ?
                                Lorin
