M30b34 E30 twin-screw supercharged muscle car
  • Ether-D
    • Sep 2011
    • 2838
    #226
    And an e28 would have had bigger tires so the taller diff (in my car) and smaller tires of the e30 should be a nice match if the transmission ratios are similar. So at 5000rpm in 5th, I should be approaching 150mph! lol...
    Originally posted by Andy.B
    I was born on 3/25…
    • Ether-D
      • Sep 2011
      • 2838
      #227
      For my own curiosity and records:
      Getrag 240 (m30) with a 2.93 rear-end in an e30:
      1st gear at 6500rpm = 41.3863636 miles per hour
      2nd gear at 6500rpm = 77.8965909 miles per hour
      3rd gear at 6500rpm = 117.138636 miles per hour
      4th gear at 6500rpm = 155.795455 miles per hour
      5th gear at 6500rpm = 192.338636 miles per hour (as if...)
      And for comparison:
      Factory Getrag 260 (m20) in an e30 with a 3.73 rear-end:
      1st gear at 6500rpm = 32.5113636 miles per hour
      2nd gear at 6500rpm = 61.1897727 miles per hour
      3rd gear at 6500rpm = 92.0113636 miles per hour
      4th gear at 6500rpm = 122.37500 miles per hour
      5th gear at 6500rpm = 151.086364 miles per hour
      I was born on 3/25…
      • Bullhead
        • Sep 2014
        • 532
        #228
        Where's the daily update up in this mofo???? Hope your doing well brosif!
        sigpic87 325E The Honey Badger
        • itskingsteelo
          • Jul 2013
          • 1340
          #229
          i think ive seen this thread go through about 7 name changes already
          Originally posted by dvck
          • Ether-D
            • Sep 2011
            • 2838
            #230
            I've only changed the name of this one twice. To more accurately reflect changing content. The M20 supercharger thread did change about 7 times.
            And I'd just like to say, what a well thought out post.
            I was born on 3/25…
            • Ether-D
              • Sep 2011
              • 2838
              #231
              I went and got the Flu (three little kids in school). I likely won't be making the Brodeo.
              I was born on 3/25…
              • Nick_S
                • Apr 2011
                • 3658
                #232
                Originally posted by Ether-D
                I beheaded my m20 car this afternoon. It had 6 bent exhaust valves. Just barely, but enough to let the water seep that I poured into the exhaust ports. This may just solve the mystery of the unidentifiable rattle. I've never been so happy to have 6 bent valves.
                This is where the magic happens…
                To think I had trouble working in my friends fully heated shop with every tool imaginable, I'm such a crier, haha. I love your threads and total DIY approach.
                91 318is M50 swapped
                05 Honda Pilot
                24V swap thread
                • LJ851
                  • 7919
                  #233
                  Where is the banjo ? :p
                  Lorin
                  The M30 is God's engine.
                  • Ether-D
                    • Sep 2011
                    • 2838
                    #234
                    Thank you for the kind words, man.
                    I was born on 3/25…
                    • Ether-D
                      • Sep 2011
                      • 2838
                      #235
                      Out of frame, but it's there...
                      I was born on 3/25…
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #236
                        Alright fellers, I got some shit did today. Got the new timing guides in and the timing chain on and timed. Timing cover and such. Then I started on the downpipes because I just recently acquired my exhaust manifolds. Boy does that rear manifold dump out right near the ole firewall. No biggie, because the m20b25 exhaust I had laying about has the damn same flanges and the perfect bend to tame that little bastard, flex joint n' all. So I got the forward most one finished and pointing toward the rear of the car and now to do the rearward one then mate up the rest of an m20 setup and call it free...er, I mean done. I reckon I should button up the driveshaft and carrier first, but anyway, made some progress.
                        I was born on 3/25…
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #237
                          Down pipes (free ones):
                          I was born on 3/25…
                          • Andy.B
                            • Sep 2011
                            • 1650
                            #238
                            Looks good!
                            Are you planning on running the stock m20 cat and exhaust?
                            What is your plan for the o2 sensor position?
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #239
                              I think I'm gonna take the duals and merge them to a single 3" right after it goes to the center of the car. I was gonna just use the m20 stuff, but I can budget in a few hundy for a muffler and some pipe.
                              On the O2 sensor bung, I think I'm gonna try and place it very near where the factory one would have been. I have an extra bung from when I bought the air/fuel gauge for my m20 car so I'm just gonna use it somehow. I haven't quite figured that part out though. I'll post up some pics when it's complete.
                              I was born on 3/25…
                              • Skafrog
                                • 1732
                                #240
                                woooooooooooooo!!! redneck!
                                NASA MidSouth TT Director / GTS2 #018
                                Mods: Coastal PS Fluid, 10w40 Oil
                                Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
