M30b34 E30 twin-screw supercharged muscle car
  • G-Man the Visionary
    • Apr 2013
    • 543
    #256
    That's gonna be sweeet! Keep it up man!
    Streetable poly mounts, trans mounts are here!
    http://www.r3vlimited.com/board/show...ght=streetable
    '94 318i
    '07 335i
    '11 X5
    '89 325ic m30b35
    • Ether-D
      • Sep 2011
      • 2838
      #257
      Just got the core support attachment system figured out and welded up. Also Ordered a couple 10' aluminized steel exhaust pipes in 2"ID from Napa. They get em next day and they were $35 each. I'm gonna put a cherry bomb on each one and do dual 2" all the way back. I know the common thing to do is 3" single, but I don't think I like the sound of single exhaust. And I wanna have a tail pipe at each rear corner instead of two on one side next to each other. Since this car is an 87, I don't have to worry about the pesky rear valance and it's sexy refined exhaust tip cutout.
      Originally posted by Andy.B
      I was born on 3/25…
      • Ether-D
        • Sep 2011
        • 2838
        #258
        Just imagine this scoop, inside painted red. Outside wrinkle black with the raised bits sanded just to the metal. M30 valve cover done up the same way. Fu-huh-huh-huh-huck! So sexy. OMgoodness.
        I was born on 3/25…
        • e30james325
          • 202
          #259
          subscribed! :)
          • Ether-D
            • Sep 2011
            • 2838
            #260
            I'm kind of surprised you are going to let that stop you... I mean, you have a drill, right?
            Edit: And I mean that in a complimentary way. You have proven yourself to be resourceful and thrifty. Why get hung up by some pesky holes that are just a smidge off?
            You know, the more I think about it, ya got a point. I'm looking at the m60 harmonic balancer ("HB" from now on), and I realized that I can change the clocking of the gap in the teeth by changing the indexing hole on the HB. I will have to have a machine shop make the inside hub-centric hole diameter larger by 1/4" and the ridge on the back side taken off as well. Then move the 8 bolt holes out 3/8" but then I get a 7 rib multi-V main pulley and a secondary 5 rib multi-V pulley for something. Maybe I have them take that off as well. I was also thinking of trying to do a single belt, serpentine style.
            I was born on 3/25…
            • Ether-D
              • Sep 2011
              • 2838
              #261
              Ok, now I done bought this from The dark side of Will here on the forum. He's a super good dude, btdubz. This is a 1.5l Opcon Autorotor OA-3150 "twin screw" supercharger. It's basically the same size as the Eaton m90 from my m20 build, but about 25% more efficient. So it makes 3-4 more lbs of boost without raising the intake temps. I'm gonna shoot for about 10psi outta this little contraption. Scrumptious.
              I was born on 3/25…
              • dadsbmw
                • Oct 2014
                • 475
                #262
                twin screw is the ONLY way to go. I have a clutched twin screw off the c32 amg waiting to go on my fun car. Good choice in supercharger!
                2003 Z4 3.0 6-speed- Silver, 19's, daily driver
                1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
                1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
                • jeenyus
                  • Aug 2011
                  • 2064
                  #263
                  Sick!
                  • chondamx
                    • 247
                    #264
                    I like this. I like this a lot.
                    '91 318is M52 Turbo (in pieces)
                    • Ether-D
                      • Sep 2011
                      • 2838
                      #265
                      Thanks Guise! So who has clever ideas about where I can tap some pressurized oil to feed it? It has an inlet and outlet on the intake side for rear bearing oiling. So I'm gonna need some erl from somewhere, and a drain also I reckon.
                      I was born on 3/25…
                      • DER E30
                        • Sep 2013
                        • 2349
                        #266
                        -Christian
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #267
                          I haven't been doing a whole lot lately, but I did start to get the exhaust figured out. It'll go from the 1 7/8" stock down pipes, to stock "H" pipe then dual into the cat. It's some 2" dual inlet/outlet high flow somethingorother. Then I'm gonna have a couple 12" glass packs then some 2" pipe back to dual 24" glass packs at the ends of the tail pipe where the factory muffler was. I have no idea how it will sound. But it will have cost me about $80. $35 for 10' of the 2" pipe, and $45 for the 2 rear glass packs. Everything else so far was from the e30 parts hoard.
                          I think I'm spending all this time on exhaust because I don't wanna a do the motor wiring. I really don't wanna.
                          I was born on 3/25…
                          • Shaffer325ix
                            • Nov 2014
                            • 37
                            #268
                            Is it a Lysholm?
                            I just junked my Mazda Millenia.. After seeing this thread I'm kicking myself for not pulling the Lysholm out of it.
                            ..Subscribed
                            1991 325ix
                            My 325ix Build
                            • Ether-D
                              • Sep 2011
                              • 2838
                              #269
                              The supercharged Mazda Mellinias had something called a "Miller Cycle" I think. Look it up on the wikipedias. It's weird. It involves the actual engine and valves and such more than other types of supercharger setups.
                              But yes, twin screw is generally referred to as Lysholm as well.
                              I was born on 3/25…
                              • Ether-D
                                • Sep 2011
                                • 2838
                                #270
                                This is the C101 pin out for 1987 325is. OMG such fear-smashing info in here. Yes. Very good.
                                I was born on 3/25…
