M30b34 E30 twin-screw supercharged muscle car
  • Eric
    • 5141
    #286
    Originally posted by Ether-D
    Not gonna doit. But I promise, when they break, I'll tell you about it.
    quoted for future mockery.
    • Ether-D
      • Sep 2011
      • 2838
      #287
      Originally posted by agent
      Hey wait a minute... those aren't side pipes?!
      It was too much. I wanted to do it, but I couldn't get the passenger side pipe over there without sacrificing ground clearance. That was the thing I was unwilling to sacrifice.
      And Eric, I reckon you quoted that so I'd remember to mock the doubters. Thanks for the reminder, but I wouldn't forget something like that.
      Originally posted by Andy.B
      I was born on 3/25…
      • Ether-D
        • Sep 2011
        • 2838
        #288
        What do you fellers think of the tips? Too ricey? I had the chrome inner tips on there but they seemed a little too far apart so I added the stainless outer parts to make them appear closer together.
        I was born on 3/25…
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #289
          Keep outters remove Inners.
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • Eric
            • 5141
            #290
            It's your build, so do what you want...But with all the fab you've talked about doing in the last 4 pages, it seams like you could have done a bit less typing and a bit more welding; then these arms could be done correctly in a few hours.
            The M30 is a heavy motor and all longitudinal forces (acceleration/braking) are hinged (literally) on the t-joint fillet welds. In the title of your build you say it's a muscle car & you plan on supercharging the motor, so I can only hope that the car will be driven with some gusto. With the potential forces applied and the weld joints in shear, especially down at the motor mount, I'd really be surprised if your radiator didn't eat some distributor cap sometime in the future. A simple piece stuck in the middle creating an H-beam would completely eliminate all shear potential on the joint. Look at most OEM arms, they are boxed or H-beam for a reason!
            What method of welding did you use? GMAW, SMAW? How many passes? SMAW you say? What type of rod?
            • slammin.e28
              שמע ישראל
              • 12054
              #291
              One conjunction: Boomtubes.
              Flat, low profile, and LOUD.
              ;D;D;)
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #292
                M30b34 E30 muscle car
                Also reinforcing the subframe will help handle the power and weight of the motor. Cause over time with weight and power it's not a matter of if but when you will twist your subframe and bend the shit out of the mounting points cause the m30 way heavier then the m20.
                • Ether-D
                  • Sep 2011
                  • 2838
                  #293
                  Thanks!
                  Be a bit more polite if you want people to listen to you. Also, spell check.
                  How many e30m30 mounts have you made? Seems like you've made quite a few.
                  I'd prefer to think the distributor cap will be eating the radiator. ;D
                  They are also made of stock that's less than 1/4 the thickness of what I used.
                  Yes, the piece in the middle will make them stronger. I will gladly eat crow if they ever bend in any way. This is how I do things. If they break, I will fix them and I will know that they should have been stronger. But if they don't break, I will know that they were great, and I will not mock you for it.
                  I used a lincoln MIG welder. Flux core .035 . Many passes.
                  In closing, don't stroll up into someone's build thread and get all critical of shit without saying one nice thing. :???:
                  Good day sir.
                  I was born on 3/25…
                  • GnarShark
                    • Sep 2014
                    • 57
                    #294
                    Haha holy sh!t, you are really turning this into a hot rod!!! This will be so rad!
                    Sub'd
                    • nighthawk
                      • Oct 2013
                      • 70
                      #295
                      I thought the m30 was actually not that much heavier than the m20?
                      Especially without ac and relocated battery. I remember reading people with these swaps saying that the weight is always exaggerated.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #296
                        From my personal experience that sob is heavy.
                        • Ether-D
                          • Sep 2011
                          • 2838
                          #297
                          I'm gonna have to weigh it. Iiiiiiiregardless, I'm adding at least 40lbs of supercharger to it as well.
                          I was born on 3/25…
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #298
                            Imo is reinforce the subframe it's 15 bucks and 30 min of welding that will save you a head ache.
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              #299
                              ;D;D;)
                              Totally do-able:
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #300
                                ^ that awesome haha
