My 1988 e30 325ix - Garage'd
The condor mount is threaded? Didn't look like it was..Build Thread
https://www.r3vlimited.com/board/sho...d.php?t=419655
Parts Thread
https://www.r3vlimited.com/board/sho...d.php?t=408302
Originally posted by jeenyus View PostWhat do you think holds up the transmission?How to remove, install or convert to pop out windows
Ended up installing a new fuel pump yesterday night. Let me say, car feels amazing. Pump solved my stalling issues too. It was most def the issue all along.
Looked dusty.
Decent size difference. I ended up having to cut a little off the base of the original support to get the filter for the Walbro to fit properly. Everything was snug as a bug though after. I used the butt connectors received from CAtuned and heat shrink.
Car runs great, idle still a little high while it's adapting, but smoother and smoother with each start. Who would have known an M20 could feel so good?
Originally posted by nando View PostThe stock mount is threaded, the condor mount is not.
Another reason i dont think that mount is a good idea is the single mount design is meant to twist when loaded up - possibly to reduce torque shock on the drivetrain.Build Thread
Parts Thread
Originally posted by Chrisbike View PostYeah, save yourself the headache, buy a oe one! Don't mess with the condor transmission mount. Basically I have a friend that just installed one and essentially he said "Don't get a Condor Mount" "Stupid fucking decision". He has GC coils/ 80a poly rear subframe bushes. Not just like he can't handle the noise/ vibration. But it actually sucks a lot, and isn't a upgrade. He just put it in last night.
I wasn't impressed with it either. It didn't fit right and the sleeve the bolt goes through was extremely loose. I didn't see how the mount was going to work. I just ordered an OE one from ECS tuning, they are on sale for 34.
So this morning I started the car and it died. It started to replicate the issues I though my replacing the fuel pump would fix...
So far I've replaced the FPR, fuel filter and fuel pump. The car should be so solid by this point, but I must have overlooked something. Im going to test the injectors and see if the orings are possibly not seated right. I'm sure they are old. It's the only thing I can think of that causes the car to stall after sitting for a 12hr period. Possibly the injectors pressurize after the engine is revved or something cause that seems to resolve the sputter and I don't experience it until it sits again.
We will see, but any advice is welcome. Injectors need to get sent to MEHP
Originally posted by Clintoxx View PostHey, another UT IX owner! I also came from the world of Audi's your username looks familiar. My was A3toxx. Either way Good luck with the IX!
Sent from my iPhone using Tapatalk Pro
That's awesome man! Audi is great, but when it comes to wrenching, BMW has been pretty fun for me. Look forward to seeing you around, I've been having a blast this snowy year.
Have you Ohm'd out your idle control valve yet? It should be like 20/40/20 or something. I had a high idle issue and it was a failed valve AND DME. The valve had some high resistance and it took out something in the DME that made it nearly undriveable. Replaced both and it was golden...just an idea.
