turbo build!!!
    • 37827
    #106
    Originally posted by e30 power
    does anyone sell some more stronger rocker arms?
    We sell the HD rockers for $300 with free shipping. ;)
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • e30 power
      • Mar 2006
      • 413
      #107
      i just sent payment ireland!!! how are those? wish i remembered you guys, i had looked at your heads not too long ago but someone gave me a link as soon as i asked.... should i still go with ireland or is your product better? havent really been in the car business for a while but still got this car
      8)8)
      • SkiFree
        • Jun 2011
        • 2766
        #108
        Quite the transformation. Sounds like you've got an awesome wife too.
        ADAMS Autosport
        • e30 power
          • Mar 2006
          • 413
          #109
          oil return fixed. no leaks now other then p/s... wich is being fixed next as soon as car is cold...
          ill have videos up soon when i get the car 100% good.... and photoshoot maybe magazine soon :D
          8)8)
          • e30 power
            • Mar 2006
            • 413
            #110
            installed this gems in earlier today...
            8)8)
            • e30 power
              • Mar 2006
              • 413
              #111
              driving it around making sure they are good to go and ill do a code of clear and clean up them rings on the gauges
              8)8)
              • e30 power
                • Mar 2006
                • 413
                #112
                so. gauges are in car has been driving good.. now time to do some more work.
                one of the things I'm having issue with is getting signal to my speedometer.... has anyone done an aftermarket speedometer before? or how/whats the easiest way to get signal to my speedometer? tried to send straight signal to the gauge from diff but no luck? am i missing something here?
                8)8)
                • blusylver
                  • Feb 2013
                  • 230
                  #113
                  someone on here posted about his aftermarket speedometer. he said it self calibrated and worked great. I seen his post a few days ago and now im searching for it. if i find it ill give you the link
                  • e30 power
                    • Mar 2006
                    • 413
                    #114
                    thank you
                    8)8)
                    • e30 power
                      • Mar 2006
                      • 413
                      #115
                      did some wiring cleaning and engine small cleaning and repositioning stuff around...
                      if this was your e30 what would you do to make this engine bay cleaner?
                      8)8)
                      • Dj Buttchug
                        • Jun 2010
                        • 7633
                        #116
                        id go new white coolant resi bottle or m42 rad. and fix the hood shocks
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • e30 power
                          • Mar 2006
                          • 413
                          #117
                          i have the new resi in mind coming soon but i may do aluminum one. just because a friend is offering to build one!
                          and shock and paint for hood piece will be done too
                          8)8)
                          • ak-
                            • 12422
                            #118
                            You can mount the P/S fluid res and relays down by the frame rail.
                            Relocate the connector C101 back towards the firewall/inside the harness cover.
                            Mount your ignition coil vertically behind the passenger headlight.
                            Put your rear headlight covers/gaurds back on with charge pipe sectioned for it.
                            M42 coolant res/radiator or remote resevior.
                            Light everything on fire.
                            Hide your blow off valve/mount it near your intercooler.
                            Get your vaccum source from somewhere else isntead of all in one place (lines look like they can kink in time).
                            Relocate the fuse box under the knee panel.
                            Different color scheme.
                            1991 325iS turbo
                            • e30 power
                              • Mar 2006
                              • 413
                              #119
                              also headlight covers behind headlights will be added on soon they coming from bmw
                              8)8)
                              • e30 power
                                • Mar 2006
                                • 413
                                #120
                                ahh nice list actually lots of good stuff here that i now want to do thank you
                                8)8)
