-- 1989 BMW E30 Turbo Delphin Grey --
This topic is closed.
  • r3kd
    • Jan 2015
    • 3
    (PICS BELOW)
    This is my very clean 1989 BMW 325i Turbo E30. A great car I must say; this vehicle is outstandingly clean inside and out since the date of purchase of 2005. Before I go into details with this vehicle, I would like to say, I babied her like no other considering this was in fact, my first car. I do have other vehicles I drive daily; but this one sits in my garage everyday waiting for a potential day to go out for a nice Sunday drive. Keep in mind this car was used strictly for shows and small drives, never intended to race on track although it can be an option for which it contains all the specific reliabilities for such an occasion. Paint is a beautiful original dolphin grey and has never sat in the sun for a long period of time. Every tune-up, maintenance, and modifications were done by me. She runs strong and fast, suspension is stable and stiff. Maintenance is kept to par. I am a certified technician so all have these procedures had been done accordingly.
    Description:
    Model: 1989 BMW 325i Turbo (3.5 years turbo) 245whp at 8psi
    Exterior: Delphin Grey/Carbon Fiber Black
    Interior: Black w/Tan headliner and floor carpet.
    Electronics: AM/FM radio, cruise control, Heater
    Engine: 6 cylinders 2.5l Turbo
    Miles: 200,000 Miles on chassis and 10,000 miles on turbo engine.
    Transmission: 5 speed manual conversion.
    Brakes: F+R Cross Drilled Rotors with Pagid Brakes 90% life great condition.
    Wheels: ESM BBS RS style wheels 16x9 all around with et10 with 3.5” deep dish lip.
    Tires: New Falken Azenis RT-615: 215/45/16 Thread: 8/32nds! 200miles on tires still new!
    Stereo: factory AM/FM radio cassette
    Modifications Upgrades
    Engine:
    M20B25 2.5l inline 6 motor.
    rebuilt reinforced head 10,000 miles
    replaced dual valve springs: intake/exhaust resurfaced head.
    guides, retainers, metric blue head studs, and thicker head gasket with copper spray.
    Stock bottom end: pistons, crank, and bore.
    Turbo Stage II intercooled setup:
    Turbo T3/T04E .50 AR cold and .48 hot
    666 fabrication Turbo adapter manifold SS 301
    Ireland Engineering turbo chip for 8-10psi boost
    Vacuum Drill 3 ports for Boost BOV and Fuel
    Exhaust Down pipe w/ flex to magnaflow 3" race exhaust.
    Oil Relocation kit
    SS braided oil lines for relocation kit
    Aluminum Charge pipes 2.5 in w/ red rubber couplings and clamps
    Charge Pipes TIG welded
    FMIC Intercooler 9x20x3 end tanks
    2 1/16in gauges and gauge holder w/ sending unit oil press, oil temp, air/fuel, boost
    Greddy Type RS BOV Adjustable soft n hard Valve
    Vaccum lines 3mm 6ft silicone
    Exhaust Downpipe 3in SS fabricated with 2 bungs
    Exhaust Full System 3in SS w/ SS magnaflow race exhaust single
    HTS Silicone Couplings and 90 adapter
    T3/T4 exhaust downpipe flange 5 bolt Steel
    FMU 12:1 High Pressure
    Spark Plugs Gap to .27mm 3 steps colder
    Oil Pan Drilled and TIG Welded with bung
    Space Age Spark plug heat guard
    Downpipe Heat wrap
    Heat Adhesive guard pads
    Oil Catch Can
    Crankcase filter for catch can
    Fuel Lines for FMU bypass
    Tial Wastegate 38mm with 8lbs spring red
    Gauge wiring Harness
    Oil Fittings feed and drain with graphite gaskets and Aluminum flanges and bolts
    Stock Exhaust Gasket w/ Heat shield 3to1
    FMIC Installed with Custom Mounts on top and bottom
    Oil Cooler Relocation
    Teflon Tape for all hardware fittings
    Vaccum Tees 3 ports plastic for BOV FMU Boost Gauge
    Oil Pan and Tranny cover bottom sand blasted
    Transmission:
    Auto to Manual 5 speed conversion Getrag 260 Redline Fluids
    Custom Drive shaft with new /guibo flex disc
    Sach stock clutch w/ 3,000 miles
    Single mass flywheel lightened to 11 pounds
    Short shifter kit from BMW Z4 2.5 for 35% shorter throws
    4.11 e30 m3 lsd differential
    Suspension:
    B+G sport lowering coil springs front and back
    Bilstein sport shocks front and back
    IE rear polyurethane shock mounts
    Sparco front strut bar
    Ireland Engineering rear stut bar
    Ireland Engineering front adjustable front sway bars 21mm
    Ireland Engineering rear sway bars 19mm w/ welded reinforcement plates to subframe
    M3 control arm bushings
    Brakes:
    Stoptech f+b Cross drilled slotted rotors
    Pagid f+b brake pads with 80% life
    Goodridge SS brake lines
    Stock gold calipers
    Redline fluids
    Wheels:
    New ESM BBS RS style wheels silver all four. 16x9 et10 w/ 3.5 lip front and back
    *only been worn for 200 miles.
    Tires
    NEW Falken Azenis RT-615 215/45/16 all four
    *only been worn for 200 miles. Still 8/32nds of tread
    Appearance:
    Carbon fiber hood from ESM
    Carbon fiber t trunk from ESM
    Genuine Hella European Headlights smiley’s with day lights
    w/ Euro grills.
    MHW smoked tail lights.
    Genuine IS front lip spoiler painted to match car.
    Front lip splitter.
    Shadow lined window trims.
    BMW mud guards
    Painted side view mirrors to match paint of car.
  • Zreberlcoe
    • 1555
    Mmmmmm very nice;D
    1991 325i Calypso Coupe
    Like Grandfather, Like Father, Like Son
    BMW
    • fight4life28
      • Apr 2014
      • 821
      Nice looking ride, I'm digging the carbon fiber hood and trunk...Alone with the smoked lights goes well.
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4513
        Car is clean as hell! That red coupler off of the turbo though.....
        needs to be black.
        • K1CKBAC
          • 306
          Are those photos taken at the CSUN parking structure?
          My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
          • Alpina
            • Oct 2004
            • 838
            That is a hell of a car,,,
            i like the list of done and extra parts
            Sveinbjörn Hrafnsson
            E30 CABRIO V12 M70B50 ///
            ALPINA B10 BITURBO 346 @ 507
            E34 550 V12 JML
            Finnish wisdom : If you want to Win,, hire a Finn
            http://alpina.123.is/pictures/
            • kalib0y
              • Dec 2004
              • 3620
              very nice
              95 7.1L 16V E36 M3
              Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
              LIKE my Facebook Page! CLICK HERE
              • esomethingian
                • Jan 2014
                • 24
                always love delphin! looks good!
                Instagram - ianstough
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  Looks great! Hope to see you driving it around sometime!
                  1992 e34 Touring- S50 Swap
                  1992 325i-S50 Swap (SOLD)
                  1991
                  • element6
                    • Dec 2010
                    • 449
                    Very clean. Thumbs up!
                    • getouth
                      • Jan 2010
                      • 3343
                      digging all but the wheels.
                      FEEDBACK:
                      http://www.r3vlimited.com/board/showthread.php?t=316212
                      BMWCCA #398608
                      IG @yagayo38
                      "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                      • ak-
                        • 12422
                        What the balls?
                        This car belonged to one of Ary's friends, sold to my friend Will, which was then s52 swapped, then sold to someone else who unfortunately had the car wrecked. This car doesn't even exist anymore. What're you doing?
                        The tags in your picture even say 2010 lol.
                        1991 325iS turbo
                        • e30abe89
                          • Oct 2012
                          • 699
                          What the? O_o lol ^^^
                            • 37833
                            x2.
                            Grover Beach, California
                            BimmerHeads.com
