cameras ready prepare to flash
  • ngampleh
    • Jul 2012
    • 466
    #136
    Here the page about rear caliper adapter..
    ETA - E30 Adapters. 420 likes. Custom BMW car parts in Jakarta, Indonesia whatsapp: +6281213208802 email: hitahimawan@gmail.com
    [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
    • iXguido
      • Nov 2009
      • 730
      #137
      Originally posted by Bggdnssnguy
      So you didn't press the bearing onto the hub first before installation? I would think you would want to press them in the knuckle as one..
      This is not possible because of the c-clip
      • iwantspeed
        • 3164
        #138
        you can tilt the diff up and place some wood or something to prop it up right so you can just switch diff bushings.
        i recommend taking the cover off and getting a new gasket.
        its a bitch sometimes to remove that stock rubber diff bushing
        drill a hole
        fit a hack saw blade through the hole.
        attach blade to hack saw,
        cut a notch/groove in the metal ring
        use a chisel to bend the ring inward on its self
        punch the ring off
        drink beer
        Project
        Parts for Sale
        Feedback
        YouTube Channel
        • s14brent
          • Mar 2014
          • 573
          #139
          Got a spare cover, diff bushing came out easily with my press. I have part of a bearing removal kit that fit perfectly.
          I tried to degrease and blast the cover but ran out of daylight. My IE bushing should arrive tomorrow!
          So I got the IE bushing today and pressed it in, but I messed up my gasket order. (I accidently ordered one for a small case) I finished cleaning up the cover and installing a new speed sensor o-ring. Local carquest will have the gasket for me on Monday.
          89 325i 4dr s52
          02 BMW 525iT m54b30/manual swapped (daily) *sold in 2020 repurchased in 2025*
          21' Toyota Tacoma TRD OR 4x4 6 speed Manual
          • brutus
            • Dec 2016
            • 596
            #140
            well done on all that effort mate !
            • jpod999
              • Dec 2015
              • 1401
              #141
              Your tool setup is awesome Brenton, that must make life so much more enjoyable ;)
              OBDI M62B44/6 swap
              Transaction feedback
              - jpod999
              • s14brent
                • Mar 2014
                • 573
                #142
                Thanks!
                I really wanted to make this as much of a DIY thing as possible. so I can't blame anyone really if the car sucks!! But yeah, I blame garagejournal if i went a bit overboard on tools this year.
                =======e39/m54b30 touring content==========
                Speaking of tools, my old 1/2" Ingersoll Rand impact won't budge the m54b30's crank bolt. I ordered a 1" impact from harbor freight (coupon was expiring last night and the store was already closed). and a 1" 22mm single socket on amazon. hopefully 1500lb will break that thing bolt free! Not the best, but for $125 for both it was the cheapest solution. The front seal is leaking pretty bad and needs to be replaced.
                The local shop that was going to order my diff gasket failed and didn't even order it, so I placed an order on pelican this morning. not doing much until that comes in, so I decided to work on the m54.
                I took off the hard coolant pipes and took off the oil filter housing. Put a fresh gasket and replaced the coolant lines with new. Good thing I replaced them, the ends were super brittle/corroded and broke off at the ends.
                I looked on real oem, and the oil pickup part #'s are different between the 330i and 530i (530/525 shared the same pn). I got a new o-ring and replaced the pickup for the 525 spare I got with the oil pan. but they looked Identical to me.
                tacked the oil pump nut because apparently its still a problem on the m54's.
                oil pan went on next. all the bolts were cleaned up on a bench mounted wire wheel first.
                Ran out of time before work, but I'll get back to the e30 as soon as the gasket arrives and I can bolt the subframe back up and run the brake cables/lines.
                89 325i 4dr s52
                • Bggdnssnguy
                  • May 2016
                  • 585
                  #143
                  I gotcha. I wasn't sure. I havent done this yet. So figured I would ask.
                  Thanks!
                  88 d21 draggin pavement
                  89 dirty30 kissin earth
                  Im just here to learn new things and meet new people.
                  • s14brent
                    • Mar 2014
                    • 573
                    #144
                    more e39 content.
                    Put in a new waterpump/thermostat. Used new grade 8.8 bolts/nuts. ECS aluminum pulley.
                    I located a m54b30 disa valve (long story short, i had a 2.5L disa somehow instead) and replaced the flapper with German Auto Solutions aluminum upgrade kit.
                    The front main seal was seeping so I tried to get the crank pulley off with my IR 1/2" impact. I soaked it in penetrating lubricant and had no luck. I ended up ordering a 1" impact from HF with a 25%off coupon. Ended up paying retail price ($129) after I got a 1" 22mm socket. This thing is so amazing. Heavy as shit, but it took off the bolt in maybe 2.5 seconds!! unreal.
                    e30 diff cover is back on. will eventually get back to that i promise!
                    ==================update=============
                    pic as promised
                    and after way too long of cleaning the rtv off the disa valve, it's finally ready to go back into m54b30 intake.
                    89 325i 4dr s52
                    • thedivision
                      • 42
                      #145
                      Awesome thread. Wondering if you tested those front brake hoses on the rear? Do they work without binding/interfering?
                      • s14brent
                        • Mar 2014
                        • 573
                        #146
                        not yet unfortunately I haven't had time to even look at the e30 lately, I have been overwhelmed with family, work and the holidays. there are a bunch of people on ngampleh (e30adapters) thread who have done this with no issue. Maybe he can chime in. I thought it was a lot easier than making a new brake line section and i'll probably use the old line to relocate the wilwood brake proportioning valve up higher when I get to installing that.
                        89 325i 4dr s52
                        • s14brent
                          • Mar 2014
                          • 573
                          #147
                          I had a bit of time today to work on the e30. It's always one step forward, two steps back with this car I swear!! :ugh:
                          I was dumb and figured out I had the parking brake shoes mounted upside down. (which is why I couldn't get the rotor over the shoes)
                          close up of the front brake lines used with e46 rear calipers
                          I ended up putting the rear subframe back up (too dark for pics) but found out the e36 m3 fortune auto rear shocks rub against the axle boot (even when preloaded)
                          CRAP.....any suggestions on shocks that will clear? I'm going to try to mess around with it later and make sure I'm not over-looking something silly.
                          89 325i 4dr s52
                          • ngampleh
                            • Jul 2012
                            • 466
                            #148
                            Looks some nice progress ;)
                            • thedivision
                              • 42
                              #149
                              Thanks for following up.
                              • ngampleh
                                • Jul 2012
                                • 466
                                #150
                                So, still thinking to buy rear caliper bracket?
