Project Frankenstein. . My journey with my E30's
  • cypriotgeeza
    • Jun 2015
    • 126
    #61
    Originally posted by MouseRat
    Just sat and read through all of this! It's quite a journey, and you have ended up with a very nice car...the M30 is the engine of the Gods ;)
    Where in the UK are you based? I've not seen many people from this side of the pond on R3V!
    Thank you for taking the time to read it mate :D Im in London what about you?
    Originally posted by CubbyChowder
    Awesome build! Have you fitted the e46 steering rack yet? I'm heavily considering this upgrade for mine.
    Thanks man :D I haven't had the time to fit it yet :oops:
    I will be fitting it soon and when i do I will update my thread 8)
    Originally posted by TimeMachinE30
    Perfect for the radiator. #14x1.75" with a fender washer using the speedclip/nut from the headlight. I had cut off the pre-exisiting ones of course to make way for the new radiator. I do not have the welding ability or capability to fashion a support. Maybe a little JB Weld? I will figure a solution to secure the bottom end. Thank you for that. You are right. It is made for the headlight sized speed clip!
    I'm glad I could help man! :up:
    "When Passion and Skill work together..the end result is often a masterpiece. ."
    Project Frankenstein :twisted: http://www.r3vlimited.com/board/showthread.php?t=359297
    • cypriotgeeza
      • Jun 2015
      • 126
      #62
      So due to this freak weather the beast is seeing alot more action then it is used to at this time of the year :D
      Here's some pics from last nights cruise up to Central london 8)
      • MouseRat
        • Nov 2015
        • 75
        #63
        I'm a bit west of London, over in Windsor. Not far at all!
        • SSE30
          • 362
          #64
          Awesome work! You have good taste in E30s.
          1991 318iS Sterlingsilber - 1989 325i Cirrusblau (sold) - 1990 318iC Brilliantrot (sold)
          • cypriotgeeza
            • Jun 2015
            • 126
            #65
            I love visiting windsor castle! Lovely area!
            • cypriotgeeza
              • Jun 2015
              • 126
              #66
              Thanks man :up:
              • cypriotgeeza
                • Jun 2015
                • 126
                #67
                Just a couple from last weekends Drive 8)
                • cypriotgeeza
                  • Jun 2015
                  • 126
                  #68
                  Update time :D
                  Ok so it's not a massive or complex update but it's one that was well needed!
                  Replaced my under bonnet insulation and what a bloody difference this made to the engine bay!! :D
                  Before
                  After
                  winkeye
                  Now I'm dreading opening the bonnet and seeing where the M30 has moulded into the insulation as it has higher points than an M20 lump :?
                  Then I focused my attention to changing the horseshoe struts and instantly ran into a bit of a problem.
                  The original cylinder is a lot thinner than the new struts
                  (sorry about the blurry pic)
                  so trying to mount them the original way wasn't happening as the strut casing was touching the Horseshoe hinge before the slot for the E-clip was visible
                  So I flipped it around and viola fits and works perfectly :D
                  Almost brought a tear to my eye how it actually stayed open on its own haha
                  No more elbow on the horseshoe while trying to manoeuvre the hood into the compartment :D:D
                  Plenty more to come soon! 8)
                  • bradnic
                    • Jul 2012
                    • 3551
                    #69
                    Late to the party but SUB'D. What a wonderful car. Phenomenal work on the M30 and great taste!
                    A couple of favors to ask
                    1) do you have any pics from underneath showing the MT1, air ducts, inner fender panels and engine undertray? the more the better.
                    2) are you willing to share the last 7 digits of your VIN so we can look up the factory options and build date?
                    thanks much!
                    HOWTOs:
                    DB vert plastic bumpers
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • cypriotgeeza
                      • Jun 2015
                      • 126
                      #70
                      thanks much!
                      Thanks for the sub :D
                      Here is the factory spec sheet i printed at work ;)
                      I'm not sure if I have any pics of the underneath at the front! I will have a look on my external hard drive and get back to you :up:
                      • bradnic
                        • Jul 2012
                        • 3551
                        #71
                        that's perfect thank you! was curious about whether the MT1 package appeared on the options sheet. apparently the answer is no :-)
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • cypriotgeeza
                          • Jun 2015
                          • 126
                          #72
                          I think it does..mine may have been fitted later :)
                          • cypriotgeeza
                            • Jun 2015
                            • 126
                            #73
                            So..this turned up today ;D
                            Now im itching to fit this!! 8)
                            Quick Q..im going to be getting the E46 rear M3 cab top mounts...What front top mounts does everyone recommend? or should I stick to good old E30 ones?
                            Also does anyone know what the letter at the top of the springs stand for?
                            The ones on my car atm have B/P
                            and the new ones have Front: B/Y Rear: C/M :?
                            • animal
                              • Jan 2010
                              • 804
                              #74
                              Nice work
                              91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
                              www.RenownUSA.com
                              ig @RenownUSA / @rude.scott
                              • CorvallisBMW
                                Long Schlong Longhammer
                                • 13039
                                #75
                                Awesome! I love this car.
                                As far as front strut mounts, do you want adjustability? If so I'm a fan of the Vorschlag mounts. Ground Control also makes good ones. If you're not concerned about adjustability, plain old OEM would be fine.
