1991 E30 325i 5-Speed - "Letty"
  • efficient
    • Feb 2012
    • 3312
    #31
    My sunroof is rusted like that. If you ever decide to take your headliner off you are going to find a lot of rust chips.
    • TURBOX
      • Mar 2016
      • 138
      #32
      i tried to vacuum as much as possible, but now im worried that the rust flakes will spread the ruts under the headliner
      [1991, E-30 325i, 5-Speed, M20, Brillantrot] [1998, B5 Passat 1.8t] [2007, R6 Yamaha] [2011, Tundra 5.7]
      • TURBOX
        • Mar 2016
        • 138
        #33
        Coolant Pipe and Pulleys Before Gold Powdercoat
        Old Timing Belt and pulleys before
        • TURBOX
          • Mar 2016
          • 138
          #34
          water pump replaced
          Taking out belts
          new cam tensioner
          Gold Powdercoted Coolant pipe
          gold powdercoat pulleys
          Odometer Gears Replaced
          Guages before in white
          Guages after in RED
          Cam seal
          New Cam Seal
          New accessory belts
          New Gates Racing Timing Belt with New Tensioner New WaterPump showing TDC
          New Gates Racing Timing Belt showing Top Dead Center
          • TURBOX
            • Mar 2016
            • 138
            #35
            thermostat 70degree
            shift rod selector
            old gummy odometer gears
            new starter
            Makk D Sylva 173 DME with 19lbs injector
            Kamoto Intake with Flex Pipe and Adaptor Plate
            Radiator Hoses - Silicone (HPS Performance)
            Garastic seat Bracket - makes the seat sit higher at the lowest setting but not that big a deal
            Clutch Master
            Clutch Slave Cylinder
            Removed old oem radio antenna telescoping mechanism thing
            New Catunning Stubby Antenna
            • TURBOX
              • Mar 2016
              • 138
              #36
              Car got T-Boned last week Friday,
              • 2mAn
                SeƱior Mod
                • 20924
                #37
                Thats not the type of update we like...
                are you ok?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5265
                  #38
                  Not what you want to see. Hope you're ok (and find the car is repairable)
                  Originally posted by priapism
                  Originally posted by shameson
