TX-IL, 1987 BMW 325is / S50 Swapped
  • 2mAn
    Señior Mod
    • 21093
    #31
    in the 24v forum theres an A/C thread, Id look in there for answers about that. as far as the wheels and getting a brake improvement, Ireland Engineering & Massive both sell wilwood setups for our cars. There is also the DIY Mazda RX7 conversion and that uses 11" rotors from a VW Corrado, so those would definitely work with your current wheel size
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • rzerob
      • Jun 2013
      • 2315
      #32
      Originally posted by b-rad
      Cleaned the mass air sensor and did re-charge of the K&N, all good!!
      Runs better, even the AC runs a bit better at idol, not perfect but better.
      Any recommendations on the AC?... $20 says someone posts "get rid of it"
      Basically if I have it in 1st the engine wants to die unless I give a bit more gas.
      Oil up the compressor or have mech/tech check the compressor?
      You need to do the idle pump. I think it is the black/gray wire needs to be grounded. I connected it to the ac switch wiring so it grounds when I press in the snow flake.
      • b-rad
        • Nov 2015
        • 232
        #33
        Looking into oil baffle, etc etc.
        Or do I invest in brakes next?
        1987 BMW 325is,(M3 S50 Swapped)-Current
        2010 FJ Cruiser, aka E30 Support Vehicle-(Daily)
        2008 Scion xB Lowered
        2001 BMW 325i
        1995 BMW 318ti
        1966 Ford Mustang Coupe
        1965 Ford Mustang Coupe
        My Thread
        • b-rad
          • Nov 2015
          • 232
          #34
          Refreshing the poly and also installing camber/toe in the rear.
          Garagistic Poly(kit) and reinforcement(rear)
          APMTuned aims to be a One-Stop Speed Shop. From Chip + ECU Tuning, Reflash + Calibration, and Dyno Tuning, to Alignments, A/C Recharges, and Oil Changes.
          Going to pick the car up in a few hours.
          Final pics to come.
          2001 BMW 325i
          1995 BMW 318ti
          My Thread
          • b-rad
            • Nov 2015
            • 232
            #35
            Raining so could not really do much with the car, testing. Feels and sounds a bit diff, in a good way.
            2001 BMW 325i
            1995 BMW 318ti
            My Thread
            • b-rad
              • Nov 2015
              • 232
              #36
              Needs some opinions on the next upgrades.
              Brakes:
              Currently I have 16" Style 5 and 88" M3 OEM brakes with street/race pads.
              Thinking IE setup for M3 Suspension
              LINK
              I wish Massive still did the Rallye kit for M3.
              Worried about fitment. Or do I recondition what I have and maybe just get new rotors.
              Oil Baffle/Cooler:
              Or do I do VAC/Achillesmotorsports baffle with Z Filter convert for oil cooler.
              I don't track the car much will be 2nd time coming up in 2 weeks.
              Would like to do more of this.
              Lots of Autocross
              Love to hear some thoughts of next evolution of the car
              2001 BMW 325i
              1995 BMW 318ti
              My Thread
              • b-rad
                • Nov 2015
                • 232
                #37
                Got the oil baffle, even with just that no ticking after hard day at track
                2001 BMW 325i
                1995 BMW 318ti
                My Thread
                • b-rad
                  • Nov 2015
                  • 232
                  #38
                  Need to figure out location for oil cooler, with ac?
                  2001 BMW 325i
                  1995 BMW 318ti
                  My Thread
                  • 2mAn
                    Señior Mod
                    • 21093
                    #39
                    you can get the oil filter housing from a S54 or the MZ3 and it has the fittings already for an oil cooler, add -AN lines and mount it up front
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • b-rad
                      • Nov 2015
                      • 232
                      #40
                      Way ahead of ya :) issue is its tight up front with ac condenser and aux fan.
                      Need smaller aux fan to place oil cooler to right
                      2001 BMW 325i
                      1995 BMW 318ti
                      My Thread
                      • b-rad
                        • Nov 2015
                        • 232
                        #41
                        Need some thoughts.
                        smaller fan to left and oil to the right.
                        should I replace the engine fan with different so that the fan for the ac comp, can be removed.
                        want to semi hide the oil cooler
                        2001 BMW 325i
                        1995 BMW 318ti
                        My Thread
                        • b-rad
                          • Nov 2015
                          • 232
                          #42
                          Another Autobahn trip. Will be getting back there soon.
                          2001 BMW 325i
                          1995 BMW 318ti
                          My Thread
                          • b-rad
                            • Nov 2015
                            • 232
                            #43
                            thinking of installing similar, my oil cooler is about the same size.
                            2001 BMW 325i
                            1995 BMW 318ti
                            My Thread
                            • 2mAn
                              Señior Mod
                              • 21093
                              #44
                              Never seen anyone use a power steering cooler, but I have heard its a problem. I plan to add an oil cooler down the road so I am watching what you end up doing
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • b-rad
                                • Nov 2015
                                • 232
                                #45
                                It's an oil cooler for me, that thread I think he has both, or 2 coolers
                                2001 BMW 325i
                                1995 BMW 318ti
                                My Thread
