Turbo m52 87 325 race car
  • skuurt skuurt
    • 183
    I bought this car to get it running and flip it... Well things didn't go according to plan so I decided a 24v swap was in store. As things progressed I decided I wanted it to have a turbo. Then it became a race car. Here's some photos of it.
    Day I bought it from up at English Racing
    Originally bought the 75d poly akg bushings but switched to solid aluminum
    ZF Transmission
    Motor mount bushings
    AKG Selector rod
    z4 shifter
    ST Sways
    1100cc FIC Injectors
    Koyo Radiator
    ARP head studs
    The Driveshaft Shop Carbon Fiber Driveshaft
    Shift knob
    Garrett GTX3582r with a TiAL .82 hotside
    Revshift Guibo
    Engine is out
    Guess it had been in an accident :(
    m52
    SS brake lines
    TiAL 44mm Wastegate
    TiAL Q BOV
    E36 M3 Steering rack
    Clutchmasters Clutch and lightened flywheel
    Innovate Gauges
    Engine is in...
    Custom made FMIC
    Sparco steering wheel
    Sparco Pro2000 seat
    [img]http://i.imgur.com/GRWBvij.jpg[img]
    Walbro 450lph in tank pump
    Turbo is mounted and on. Vband custom exhaust manifold
    Steering wheel is mounted to its quick release
    Seat is in
    Solid bushings
    Haltech Cluster
    Fiberglass blank dash
    Fender flares
    Slowly coming together
    Rear tires arrived. 275/50r15 Nitto NT555r
    Mounted onto my Diamond Racing steelies 15x10 in rear 15x9 in front
    Front tires are 225/45r15 Nitto NT05. Heres the size difference between the front and rear.
    Custom fuse panel and standalone mount for the Haltech Elite 2500
    Dash mounted
    Test fitting
    Fuel injectors in
    Custom surge tank time
    That's all for now. This is 2 years progress. Suspension will be finished this week along with fuel lines. Dyno tuning next week. Updates as I can.
    1987 325 project
  • Jaker
    • Oct 2013
    • 234
    Is it too late to get an accurate weight on the DSS CF driveshaft?
    • skuurt skuurt
      • 183
      No, it's not. I'm having a rear subframe remade to fit it through the tunnel, run a e46 diff with some custom dss axles.
      1987 325 project
      • efficient
        • Feb 2012
        • 3312
        Cool build. In for more pictures
        • Jaker
          • Oct 2013
          • 234
          Great. I'm trying to drop weight off my E36 any way I can. I'm not sure I want to drop the coin that DSS wants for that driveshaft, but if there's some weight to be saved over my current 16 3/4 lb OEM driveshaft I might take the plunge.
          • skuurt skuurt
            • 183
            Well it's rated at 20 lbs. I believe shipping weight was 22lbs. So if yours is around 16, it will had weight
            1987 325 project
            • Jaker
              • Oct 2013
              • 234
              I have a hard time understanding that, but I know for certain that my current OEM driveshaft is 16 3/4. I weighed it on a digital fish scale.
              • ak-
                • 12422
                Haha I was like damn you work fast till I read the 2 years progress part.
                Excited to see how all this turns out. You're doing a few things you hear people do, but never really post much about which is awesome.
                1991 325iS turbo
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  This is awesome!
                  1991 318i 4dr slick top
                  Mtech 2 turbo restoration
                  • Pootis
                    • 636
                    Wow this is am awesome build
                    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
                    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
                    • skuurt skuurt
                      • 183
                      updated photos from this week.
                      1987 325 project
                      • Northern
                        I like cupcakes & sh!tboxes
                        • 5265
                        Not sure if you could take an up-close picture of the weave on the carbon DS, maybe with a coin for scale? Just interested on how large and what sort of weave they use for it.
                        I think the revshift guibo with the carbon one piece shaft may be a recipe for disaster too. The OEM guibo holds a hell of a lot of power, and with both the DSS shaft and revshift guibo both being well known for adding vibration, it might lead to a problem in the future.
                        Also, which turbo manifold is that? I didn't see anything about it
                        Originally posted by priapism
                        Originally posted by shameson
                        • AusScare
                          • Jun 2014
                          • 220
                          What an awesome build! What're your plans for brakes?
                          '90 318is
                          • Anthony B
                            • Nov 2012
                            • 308
                            Solid work! From the background of the workshop photo looks like there is some fun cars being built there.
                            Looking forward to see the work progress
                            • Sh3rpak!ng
                              • Jan 2014
                              • 2667
                              Damn cool project, subbed! Looks like you do great work!
                              Also in for more details regarding the haltech. I never really knew much about them until I started watching mighty car mods, and lately I've seen a couple builds using them.
                              Shadetree30
