Mike's Alpine White 1991 318is
  • fresh_TD
    • Aug 2013
    • 2457
    #481
    It was good to see you this morning, Mike. Car looked great, as always!
    Sent from my Pixel 3 using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • jeenyus
      • Aug 2011
      • 2064
      #482
      This should be on a nice set of coilovers. It totally deserves it.
      • mike.bmw
        • Dec 2015
        • 1777
        #483
        Thanks, all!
        Respectfully disagree. ;D
        This is exactly how I want my car to sit. I spent a significant amount of time researching springs, shocks, mounts, etc and refurbished most of the suspension. If I did go the coilover route, I'd raise the car to it's current height, pick dampening settings similar to the Bilsteins on the car, and choose a spring rate similar to the H&R OE Sport Springs. :)
        I don't disagree that a lowered E30 looks great, but it's just not something I want to do with this car.
        • mike.bmw
          • Dec 2015
          • 1777
          #484
          Safety First!
          freeride53 recently inspired me to get a fire extinguisher based on a post in his thread. It's something I've been meaning to do since I bought the car (after recognizing and replacing all the leaking fuel lines). I just never spent the time researching brackets and extinguishers until last week.
          I ended up with The Bracketeer and a Buckeye 13315. The Bracketeer is a universal fire extinguisher mount and the Buckeye extinguisher had good ratings and came with a vehicle mount.
          Initially I mounted it driver's side, but then decided to move it to the passenger side. I modified the bracket so that it could be bolted to the seat rails. The way I've mounted this it does prevent the seat from moving all the way forward, but the does still have a good amount of forward movement. It also allows the seat to be tilted forward to so I can get the kids in their car seats.
          Moved to passenger side:
          So for less than $100 I have a fire extinguisher mounted in the car. Hopefully I never have to use it.
          • getouth
            • Jan 2010
            • 3343
            #485
            Mike you have a pm
            FEEDBACK:
            http://www.r3vlimited.com/board/showthread.php?t=316212
            BMWCCA #398608
            IG @yagayo38
            "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
            • jeenyus
              • Aug 2011
              • 2064
              #486
              Originally posted by mike.bmw
              Thanks, all!
              I can respect that.
              I have a super low car and I don't like it, but I do like the performance it yeilds in certain driving conditions. To find the sweet spot between those two is what I'm referring to I guess. For example my e91 is on stock suspension and the height is perfect, but definitely needs some stiffer springs and that's hard to get without dropping the car a little. Coilovers I feel could encompass both ideas in one without much compromise between the two.
              Sent from my Pixel 2 using Tapatalk
              • freeride53
                • 11972
                #487
                Haha nice! Better safe than sorry. Jealous of your “correct” 318is Natur perforated sport seats and beautiful shape. My sport seats (though saved my life in my old car’s wreck) are ugly Pearl beige.
                1983 Peugeot 505 STI
                1992 Volvo 240 Wagon
                • Albie325
                  • Jul 2016
                  • 515
                  #488
                  Nice work with the extinguisher, been thinking about installing one and this is one of the nicer, cleaner setups I've seen
                  '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                  Albie325 Build Thread | Albie325 COTM Jan 2021
                  • mike.bmw
                    • Dec 2015
                    • 1777
                    #489
                    Thanks! The seats are in pretty good condition, except the driver's side bolster next to the door. The vinyl is cracking and needs to be replaced. I may just replace that section if I can find something that matches. I think the Pearl Beige looks good too!
                    Thanks! The mount has been solid and rattle free. The only change I've made is I've rotated the extinguisher so the handle would face the floor. It's pretty much out of sight, but still easy to access. The only modification I had to make to the bracket was cutting off the ends of the U shaped brackets. Ideally I'd make new brackets that would fit/reach UNDER the sliders so that the bracket wouldn't prevent full forward movement. Either mounting option, the extinguisher would be in the way so the seat can never go fully forward.
                    • dmanb2b
                      • May 2018
                      • 367
                      #490
                      Looks great Mike!
                      1991 318is
                      2004 330ci
                      2011 335d
                      • mike.bmw
                        • Dec 2015
                        • 1777
                        #491
                        The Vintage 2020
                        I booked my room at the Clarion! I'll be bringing my wife. My kids will have 3 spoiled/pampered days at Grandma's house. Very excited to attend my first Vintage!
                        HPDE Prep
                        I'm registered for the 2 day BMW CCA NCC HPDE next month. I'll be taking my car to RRT for the required tech inspection (RRT does this for free) and an alignment (because I still haven't done this).
                        What's that smell?
                        I've been tracking down an intermittent fuel smell. I tightened down all the hose clamps in the engine bay. I inspected under the rear seat. Everything looks good and the smell hasn't come back. Very clean under the rear seat!
                        Dash Protection
                        After swapping in a crack free dash nearly 2 years ago, I've become very dash-crack conscious. I apply 303 on a regular basis. I always use a sunshade when parked. I picked up a Dashmat (limited version from Covercraft). The fitment is so-so. It does a good job of keeping the dash cool while driving on long trips in direct sun. It rolls up and stored easily when not in use. For $35 shipped from Advance Auto Parts, it's not a bad deal.
                        Garage Organization
                        I've found some time to thoroughly go through my garage and organize it. Things are binned by type (paints, lubricants, new car parts, old car parts, and so on). I moved a few things around based on frequency of access. It's always nice to work in a clean, organized garage.
                        Fresh_TD snapped this when I was leaving C&C the other day.
                        And I got this one parked near his super clean E21.
                        • columbo_01
                          • Aug 2018
                          • 101
                          #492
                          Nice pics Mike. As always, very clean e30.
                          • jeenyus
                            • Aug 2011
                            • 2064
                            #493
                            Where is vintage again? Sent from my Pixel 2 using Tapatalk
                            • fresh_TD
                              • Aug 2013
                              • 2457
                              #494
                              Asheville, NC Sent from my Pixel 3 using Tapatalk
                              • Albie325
                                • Jul 2016
                                • 515
                                #495
                                What are the dates for the Vintage? Can't seem to find it online and want to request off of work now so I don't miss another one.
                                Also, very jealous of your C&C's, I wish we had something like that around the Raleigh area. I haven't been able to come across much on the local interwebs.
