Mike's Alpine White 1991 318is
  • mike.bmw
    • Dec 2015
    • 1768
    #586
    Originally posted by dmanb2b
    Mike, hope all is well. Quick question for you...Did you end up adjusting the stalks or does the MT2 sit lower than your new wheel, so no adjustment needed? Thanks
    Hey! Hope all is well with you too.
    The Sport Wheel sits the same distance away from the stalks as the 385mm MT2. The center of the Sport Wheel looks a bit more concave than an MT2 wheel, but the spacing and distance from the stalks are the same. The Sport Wheel measure 385mm across.
    I haven't bent my stalks. It's a tad close, but doesn't really bother me. For reference, I'm 6'5" and can easily palm a basketball, so it's not like I have tiny hands. If I were to wear gloves at a track day, I'd likely hit the stalks every time as there isn't much clearance now. Also, if this was a 370mm wheel I'd likely have issues with my knuckles hitting the stalks, but I don't have that issue with the 385m wheel.
    If someone comes up with a cool spacer solution to extend the wheel towards the driver, I'd be all for it as that would be a more comfortable driving position for me.
    I have a few updates coming, but I figured I'd stack them up as opposed to posting lots of smaller updates.
    • dmanb2b
      • May 2018
      • 367
      #587
      Thanks as always! My 370mm is currently installed with the additional spacer under the wheel, which must be why my horn doesn't work. I'm 5'11 and the wheel sits perfectly for me. I don't mind the gap between steering column. but not having a functional horn is a deal breaker for me, especially with all the testing and driving. I may try it out and see if I can adjust my seating position some to compensate and then bend the stalks or replace them with non-airbag stalks.
      1991 318is
      2004 330ci
      2011 335d
      • D.Martijn
        • Sep 2016
        • 1024
        #588
        I know there is a build thread where someone mentioned spacing the steering wheel away from the dash but unfortunately they didn't respond to my question..
        I'm 2m04 or 6'8" so I'm having the same problem..
        1990 325iX Touring - November 2018 R3V Car Of The Month
        1980 Volkswagen Golf mk1 1.1
        1974 BMW 2002 Touring
        Instagram
        • mike.bmw
          • Dec 2015
          • 1768
          #589
          I think I saw your question in freeride53 's thread. I didn't see a response though. I'd love to know as well!
          I fit in the E30 reasonably well. Almost better than my F31. I just wish the steering wheel telescoped as my seat is nearly all the way back, but arms are extended more than I'd like reaching for the steering wheel. I'm sure you have it worse than me with the extra height.
          Regardless, these cars are just so fun to drive the "fitment issues" don't bother me much.
          dmanb2b , if your horn doesn't work, you'll need to extend the telescoping rod. I have very little fabrication skills, but you might be able to swap out the existing rod for a longer one so it makes contact with the horn ring on the back of the steering wheel.
          • D.Martijn
            • Sep 2016
            • 1024
            #590
            Yeah, just had a look. I've sent him a pm before but that didn't result in a reply either.
            My parents have an F31 as well, I have no problems with fitting inside that one. Although it's like I'm driving a sofa (seating position and feel) compared to the mk7 GTI/E30 hahaha.
            Yeah, I feel like I need to sit closer to the wheel to have a decent reach for my arms but then my knees sit way up and are hitting the steering wheel making it almost impossible to turn the wheel.
            Instagram
            • mike.bmw
              • Dec 2015
              • 1768
              #591
              A couple of updates!
              Cracked Console Repair
              Since I bought this car over 4 years ago the center console has been rattling and squeaky. Despite having the center console out many times (to include swapping the dash), I've never bothered to fix it. A couple of weeks ago I was driving to work early in the morning and I finally had enough. I ordered some JB Weld Plastic Bonder, used some junk in my tool box, and now it's solid as a rock.
              The cracked mounting tab didn't allow the parking brake console to seat, causing many rattles and squeaks.
              20200513_144809 by mike.bevels, on Flickr
              I used a cable holder as a filler piece.
              20200513_145003 by mike.bevels, on Flickr
              And then I bonded it in. The JB Weld Plastic Bonder works great. It's a bit ugly underneath, but you can't see it from the top and it's VERY solid.
              20200515_145108 by mike.bevels, on Flickr
              Heater Valve, Heater Core Replacement
              While I was repairing the center console, I noticed the joint between the heater core and heater valve was weeping. Not dripping. There was barely any liquid on the joint, but it was there nonetheless. Originally I thought about just replacing the o-rings, but my heat has always been a little odd. To get hot air I'd have to turn the dial to full hot. It was either full cold or full hot, not much of a transition between the two. So I decided to replace the valve and heater core while I was in there.
              Original equipment:
              20200520_151506 by mike.bevels, on Flickr
              20200520_151137 by mike.bevels, on Flickr
              Disconnect firewall hoses:
              20200521_101836 by mike.bevels, on Flickr
              Remove heater core and drain any additional coolant in the lines. I had a plastic tarp underneath to catch any coolant that I missed, but I got lucky and not a drop hit the tarp.
              20200521_103933 by mike.bevels, on Flickr
              Old and new pieces. Notice the different design of the heater valve.
              20200521_123643 by mike.bevels, on Flickr
              The heater valve top actually rotates so you can fit it correctly (it's larger). Then you hand tighten the nut to lock it down per the single page of instructions:
              20200521_123632 by mike.bevels, on Flickr
              New foam around the new heater core:
              20200521_125713 by mike.bevels, on Flickr
              New heater valve in place. O-rings lubed. I removed the piece of yellow tape before putting it together (it was a sticker from the original coolant pipe).
              20200521_130053 by mike.bevels, on Flickr
              I took the time to vacuum all the crap out of the heater core's home:
              20200521_130457 by mike.bevels, on Flickr
              Mostly back together:
              20200521_135811 by mike.bevels, on Flickr
              I left it all apart and went for a drive to check for leaks. No leaks in the interior, but there was some weeping from one of the hoses in the engine bay. I tightened it and may replace it later. The heat works great now. I get a nice gradual transition from cold to hot.
              Big thanks to my kids for being on flashlight duty as I knocked this out!
              • roguetoaster
                Biggus Tippus
                • 7830
                #592
                Looks great! However, it also looks like it might be time for a new brake booster grommet and maybe even a new valve if you feel like replacing the original. Parts are something like $50 if you already have some good hose clamps around.
                • mike.bmw
                  • Dec 2015
                  • 1768
                  #593
                  Thanks and keen eye! I also noticed this. It's on my list of things to replace. It's not currently causing any vacuum leaks (that I can detect), but it's always good to be proactive. :-)
                  • Nate37
                    • Sep 2019
                    • 80
                    #594
                    Nice job and thanks for the clear posts, Mike! Saved this in case I ever need to do the same.
                    • D.Martijn
                      • Sep 2016
                      • 1024
                      #595
                      Nice work Mike. Does yours have AC? I've been told on non AC cars the steering column is in the way making it a fair bit harder to replace the heater core.
                      Instagram
                      • mike.bmw
                        • Dec 2015
                        • 1768
                        #596
                        Thanks. I found this post (and the 15 pages of comments following it) very helpful: https://www.r3vlimited.com/board/for...core-and-valve
                        Thanks! D.Martijn , my car does have AC. As Ed China would say, "it was a bit fiddly", but fairly straight forward. I'm not sure my left shoulder was meant to bend in the directions it bent yesterday. I believe the steering column rivets need to be drilled out for cars without AC as the components are different and oriented differently, making removal and replacement much more difficult.
                        • Albie325
                          • Jul 2016
                          • 515
                          #597
                          Nice job Mike! I remember doing this with everything out of the car and figured it'd be a pretty tight fit but looks like you had great access with the center console removed
                          '86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
                          Albie325 Build Thread | Albie325 COTM Jan 2021
                          • mike.bmw
                            • Dec 2015
                            • 1768
                            #598
                            Thanks! Access wasn't ideal, but it wasn't terrible. This would have been much easier when I had the dash out (swap) a couple years ago. You might be pleased to know that I've continued to make use of the foam you sent me! Was that last year? I've completely lost track of time... Anyway, thanks again for that! You rock.
                            I drove around for a few days without the knee pad or lower cover in place to check for leaks. Plumbing of any kind (house, vehicle, etc) always makes me paranoid. Yesterday after a long drive with the kids, Avery buttoned up the rest of the dash almost entirely by herself.
                            20200524_152331 by mike.bevels, on Flickr
                            And then we washed the car. I drive the car a lot, but usually not in the rain, so it generally stays clean. It had been over a month since the last wash, so we thoroughly cleaned inside and out, to include the engine bay.
                            20200523_135654 by mike.bevels, on Flickr
                            20200523_143811 by mike.bevels, on Flickr
                            And this morning I got out before sunrise for some photos. Taking early morning photos is quite calming and enjoyable. It's so early that no one else is out!
                            DSC_0768 copy by mike.bevels, on Flickr
                            DSC_0739 copy by mike.bevels, on Flickr
                            DSC_0723 copy by mike.bevels, on Flickr
                            • e30mclow
                              • Jun 2010
                              • 195
                              #599
                              This is the car that comes to mind while I sit looking at mine, wondering if it'll ever be clean.
                              • mike.bmw
                                • Dec 2015
                                • 1768
                                #600
                                This is a small update, but updating this thread motivates me to keep working on the car, so here we go...
                                Brake booster check valve, grommet, and vacuum hose replacement
                                Big thanks to roguetoaster for pointing out I needed to replace my brake booster grommet and then giving me the part numbers for some of the NLA items that I ordered. I ordered new booster vacuum hose, a new grommet, and a new check valve. I already have plenty of BMW hose clamps, so I didn't need any more of those. The check valve is NLA, but the E36 version works well (part # 34331156579).
                                It's a good thing I replaced everything as the hose was hard and brittle and actually had cracks on the back side. The connections were all rather loose too. It probably wasn't causing a massive vacuum leak, but after replacing these parts the small "dip" in idle I used to see when coasting to a stop has now gone away completely.
                                Old and new:
                                20200531_123906 by mike.bevels, on Flickr
                                Installed:
                                20200531_125048 by mike.bevels, on Flickr
                                Strut mount caps
                                Apparently these come in different sizes. My old caps were too small for my new strut mounts. BMW sells a 32mm version that fits the strut mounts with larger openings.
                                20200531_162128 by mike.bevels, on Flickr
                                Garage lighting and cleanup
                                I hung up 2 additional lighting fixtures in the garage. One over the tool chests and desk, another in front of the shelving. These things are BRIGHT. I also did a better job of tidying up the wiring and securing it to the ceiling. In addition, I spent a few hours cleaning out the garage attic and I can now use that for organized storage. Now I just need to get to cleaning and organizing everything on the shelves, and paint the ceiling, and do something with the garage floor...
                                20200530_142448 by mike.bevels, on Flickr
