Originally posted by Levy3Poop
View Post
Ruby's Thread
Long time no update. I haven't been driving Ruby nearly as much since I got the Fj cruiser, but Lindsay and I took Ruby for a spin the other day with Astro in the back, and man....I had forgotten how much a joy she is to drive.
I'm motivated to get the engine swap done more so than I have been in a long time.
One of the things that was holding me up because I just wasn't sure about was the brake booster. I knew I need a new one for the 24v swap.
I found that Tangent Innovations makes a plug and play adapter for the E60 brake booster, So i ordered that and a booster off amazon.
That means I have less excuses to not get to work!
I went ahead and finally put on the new thermostat for the M54 yesterday. It was just sitting in the box under the engine on the stand.
I took a dremel with a brass wire wheel to the mating surfaces first to make sure the seal was good, and popped the new thermostat on.
Nice, now for another small and easy thing I found in my box of M54 parts: the oil filter housing gasket!
Hmm...that gasket looks like it was new already, and that mating surface looks like it's been wire-wheel'd already...Have I done this before?
Oh well, the one from the bag in the picture is now on the engine.
Baby steps. I have tons of parts for this swap that I JUST NEED TO DO!
I'm so frustrated with myself taking forever on this.
I just have to keep SOME progress coming regularly and not get used to stagnation.
- Likes 1
Another small update on the M54. The other day I wire wheeled the mating surface, and replaced the water pump.
Here's the pump-hole after I treated the surface
Here's the guy that went in. It's got the metal assembly with the metal fins, so no plastic./
The o-ring was a bit too grippy, so I just put a thiiiin layer of anti-seize on it to help the water pump slide into place.
Here she is all installed and ready for action!
I was bored, and even took the brass wire wheel to the nuts haha
it's quite satisfying to watch the hardware turn shiny in front of you
I also cleaned up the mating surface for the VANOS gasket
That's it for now. Baby steps will keep me from standing still again!
I figured it'd rather the bearing on the fan go out prematurely due to always running on high than the resistor burn my car down haha
Okay time for a long awaited update. I DO still own Ruby, just haven't driven her much since getting my FJ and life moving on, ya know?
I got all our cars inspected this last May, and after getting Ruby inspected, on the way home, she started overheating. When I got home, I could see there was a definite coolant leak coming from the radiator. Either a split hose, crack in the plastic, or something to cause a leak and not just a sudden gush of coolant.
I'm not going to replace the M42 radiator. I've gone ahead and taken this as my sign to get my ass in gear on the M54 swap.
First order of business! A radiator for the M54:
I got the Mishimoto Performance E30 radiator. Not sure how much adapting and custom work I'll have to do to make it fit in my 4 cylinder (product page specified it was for 6 cylinders), but I've got a welder and loads of little scrap metals and a hard head to make things work.
I also got the 6 cylinder E30 coolant reservoir expansion tank, bracket, and hoses to accompany the radiator.
Second order of business: I got the safety-wire oil pump nut on and installed, as well as finally smacking in the front main seal using a custom tool I made that fits around it.
I just took some old engine oil around the main seal, my tool, and a rubber mallet, and *tap tap tap*ed it in with no issues. No idea why I had procrastinated or felt intimidated by this seal originally.
Next up was another kind of expensive part I wasn't really wanting to spend the money on: the alternator.
I went with the Bosh 120a alternator. Thanks to Amazon returns, this one was like new for $180 or so and looks to be perfect!
The next challenge that's intimidating me is radiator hoses. i can't really seem to find any clear cut guides on what hoses to get. Any tips?
- Likes 2
