Dmanb2b's Alpine 318is - S52 is ALIVE
  • dmanb2b
    • May 2018
    • 367
    #31
    Originally posted by dadsbmw
    Curious what tire size you ended up going with? Also, are you running adapters, or have you done a 5-lug swap?
    I will probably regret this but trying to squeeze 205/50. I went with 18mm front and 20mm rear 42 draft design adapters. The setup will like require fender rolling and/or pulling. Keep you all posted. Should have new tires next week.
    1991 318is
    2004 330ci
    2011 335d
    • rjsimeon
      • Jan 2019
      • 97
      #32
      Wow, you have been doing some work. Lookin awesome! Sent from my iPhone using Tapatalk
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        #33
        205's should be fine on an 8 with final ET3 with maybe a light roll. Might get away with 225's with a good roll even.
        Originally posted by priapism
        Originally posted by shameson
        • dmanb2b
          • May 2018
          • 367
          #34
          That's the plan...Thank you!
          1991 318is
          2004 330ci
          2011 335d
          • dmanb2b
            • May 2018
            • 367
            #35
            Thanks, looking forward to enjoying the car
            1991 318is
            2004 330ci
            2011 335d
            • dmanb2b
              • May 2018
              • 367
              #36
              Forgot about this gem in the trunk
              1991 318is
              2004 330ci
              2011 335d
              • dmanb2b
                • May 2018
                • 367
                #37
                Setting ride height. Rear is where I want it and front needs to come up about 1/2"
                1991 318is
                2004 330ci
                2011 335d
                • dmanb2b
                  • May 2018
                  • 367
                  #38
                  Trying to get final to-do list organized
                  1991 318is
                  2004 330ci
                  2011 335d
                  • dmanb2b
                    • May 2018
                    • 367
                    #39
                    Shop had a spare driveshaft laying around. I would still like to find one to replace their inventory, except everyone wants to charge M3 prices...lol
                    1991 318is
                    2004 330ci
                    2011 335d
                    • dmanb2b
                      • May 2018
                      • 367
                      #40
                      S52 getting wired up..OBD1
                      1991 318is
                      2004 330ci
                      2011 335d
                      • dmanb2b
                        • May 2018
                        • 367
                        #41
                        Exhaust parts coming together as well
                        1991 318is
                        2004 330ci
                        2011 335d
                        • dmanb2b
                          • May 2018
                          • 367
                          #42
                          Back in the shop...working on cooling system...don't worry about the missing driver's seat...haha
                          1991 318is
                          2004 330ci
                          2011 335d
                          • benwalsh91
                            • Jul 2018
                            • 255
                            #43
                            I could have made you 15mm 4x100 to 5x120 adaptors if needed.
                            I drove my e30 from California to London!
                            • dmanb2b
                              • May 2018
                              • 367
                              #44
                              Got any pics or links? Depending on how this fits, I may be interested. I thought most won't go below 18mm, for safety reasons, so curious what your setup looks like. I'd much rather run 15mm in front and 18mm in back.
                              1991 318is
                              2004 330ci
                              2011 335d
                              • benwalsh91
                                • Jul 2018
                                • 255
                                #45
                                I have an Instagram page called @adaptorsbyben which has photos of cars that run my adaptors which range from anything all the way up to high end Audi RS models and even have a couple of Lamborghini's running them. i don't really advertise too much its more just Instagram and word of mouth.
                                its perfectly safe to run 15mm but i wouldn't make them any smaller. The issue you have is the standard thread on a bolt is normally 18mm so the bolt will bottom out so you have to trim them. However, if you fit a stud kit on the adaptor you wont have an issue of them bottoming out or needing to go through the painful process of trimming 3 down on 20 bolts.
                                I am in England, but i do ship anywhere in the world, last time i sent some to California i believe it cost me circa £40 for the post and that was airmail 5 days, insured and recorded.
